drawk
Hi all - I have a 'silverfish style' bottom discharge 36v battery. I need to adapt it to another application, and so would like to run a lead from it soldered to a different connection type (to be determined, but probably a male kettle style plug) - however, I am not familiar enough to know what this two-blade connection type is even called.
I did find a lead at https://pirez.com.au/silverfish-lithium-ion-battery-bottom-discharge-connection-plug-cable and this seems to be the only source I can find. I suspect that I am just googling wrong, however, not knowing the proper name for this connection type, if there is one.
Basically I want to plug a male lead into the bottom of the battery and run off that.
Thanks, and apologies if this is an embarrassingly basic question.
[edit: corrected url]
