mjp8081
This is probably a simple question.
What is the term for a BMS board that shares its charge and discharge input output, i.e. no separate charging port or terminal?
I am trying to replace a BMS board from a "drop in lead acid replacement automotive/marine type to LiFePO4 cell deep cycle battery", which charges and discharges both through the main terminal posts (like lead acid) to work in auto/boat 12v systems.
I don't know what the technical term/terminology is for this type of BMS board design, I'm trying to source (by googling)for a replacement or maybe a repair service, but I need to know what its called.
Basically I need help Googling it.
Thank you wise ones.
http://elithion.com/lithiumate_lead_acid_replacement.php
