Hi all,
I'm building my first battery pack and have some questions,
A month ago i got 10pcs of 2200mAh 36v packs with 10 cells each that seems to be a brand new but a little bit old (about a year or 2),
After testing each cell out of those 100 individually, the average capacity of them is 2050mAh (between 1500 to 2300).
Now i'm thinking if i should go for 13S7P or 13S6P,
if i'll go for 7P the lowest cell capacity will be 1500mAh,
if i'll go for 6P the lowest cell capacity will be 1800mAh,
considering that i want to get as much Amps as possible (and of course capacity as well) i'm thinking to go for 7P but i'm afraid that using those extra 13 weaker cell will affect the whole battery performance.
is it true? what should i go for?
another question - i also checked the resistance of each cell before discharge and after discharged, the results was between 66ohms to 160 while most of them are around 110, after full discharge the resistance was a little bit higher.
which one is the correct result ? and what should i think of when i'm splitting the cells to parallel groups resistance wise ?
Hope it was clear enough,
Thanks!
Thanks!
