Wire or Cable size? 100ahr 12.8V Lifepo4
Post by hydeal2 » Dec 05, 2017 8:16 pm
Building own battery packs for my boat trolling motor and outboard. Need to know the wire size and type to use from cell terminal to battery pack case terminal?
-Length of cable on both terminals is maximum 7".
-Compression ring terminals used at both ends.
-Water tight PVC Case.
-Thru Panel stainless terminals used on case.
-600 amp 1-2 second/cycle/200 amp 20 second cycle/80 amp continuous
Any help would be great-full!
Re: Wire or Cable size? 100ahr 12.8V Lifepo4
Post by dustNbone » Dec 05, 2017 8:44 pm
For a run like that I'd want at least 2AWG, but 4 would probably be fine. But generally for inside the box like that, I cram in the biggest one I can reasonably fit.
Post by Sunder » Dec 05, 2017 9:42 pm
7" of 4 AWG @ 600A = 51 watt loss
7" of 2 AWG @ 600A = 33 watt loss
7" of 4AWG @ 200A = 5.7 watt loss
7" of 2AWG @ 200A = 3.6 watt loss
7" of 4AWG @ 80A = <1w loss
7" of 2AWG @ 80A = <1w loss
As long as your times are accurate, I'd say dustNbone is spot on. I would not like to see 51w of heat dumped across just 7" of cable for any significant period. Short cables = low resistance, but short cable = smaller heat sink...
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 on 36S
eCar: Mitsubishi Outlander PHEV... Waiting for warranty to expire
eHouse: Still on grid, but with LTO batteries and 3kw LF inverter...
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
Post by fechter » Dec 06, 2017 9:45 am
How much current does the motor actually take?
