trickle charging lithium
Hummina Shadeeba
Post by Hummina Shadeeba » Jan 02, 2018 11:32 pm
its said that trickle charging is not only bad for cells but even dangerous but what exactly would trickle charging be? When I bulk charge with a meanwell or some other constant voltage source and the pack is getting close to the supply voltage the amps going to the battery will go way down to a trickle, but is this trickle charging? what if I were to set it to 4.2 or 4.1 per cell? Can I have the battery sitting on the 4.1 voltage all day?
amberwolf
Re: trickle charging lithium
Post by amberwolf » Jan 03, 2018 1:26 am
fechter
Post by fechter » Jan 03, 2018 10:43 am
If you leave the cells at 4.1v all day, it does not hurt them. Whether the charger is turned on or not doesn't change what's happening inside the battery. I don't consider this trickle charging.
Trickle charging was used on NiCd in the old days and was a constant current charger, which would be bad for a lithium battery as it would try to push some current regardless of the cell voltage.
Hummina Shadeeba
Post by Hummina Shadeeba » Jan 03, 2018 1:55 pm
thanks guys for the info and links above, there's a good one. The cells at 4.2 either on the charger or not makes no difference. makes sense.
