Hello All,
I apologize in advance as I am relatively naive to the world of lithium ion batteries. I am looking to construct a 12V 90Ah battery from 26650 3.7V 5200mAh cells. First, how should I configure these cells for spot welding the nickel plating? Series, parallel, yeah yeah... diagram please!
The load this battery will sustain will never be more than 30Ah. Knowing this, what battery management system should I select?
Last, what is the quickest charger I can select based on the 12V 90Ah battery with what I imagine is maybe a 35Ah limiting BMS?
***I realize exactly a 12V 90Ah battery isn't possible, my guess is with the cells configured properly I will arrive at an 11.1V 93.6Ah battery pack.
Thank you all for your help, it is greatly appreciated.
