billvon said:
There's no "sudden braking failure." In unusual conditions (100% charge) you can lose regen, which is generally a small percentage of the total braking power available from your brakes. So you squeeze a little harder and get exactly the same braking. Unless you are following six inches behind someone it won't matter.
As I noted previously, that depends on how your braking control is setup.
If your ebrake is a separate control from your mechanical brake (like on my trike and my bike where it's a separate brake lever), then if you don't have that mechanical control already under your grip (or foot, or whatever), it will take your reaction time plus movement time to begin mechanical braking.
Some vehicles' electric braking controls are not even in the levers (or foot controls) at all, and are controlled solely by the throttle, or by the throttle in combination with a button or other control. IIRC the Vectrix uses its' throttle in a reverse twist to engage braking. Some ebike controllers with proportional regen do something similar; some require engaging the ebrake signal first. I dont' remember if any can be used without doing that, but the signal doesn't have to be on a brake lever.
As for how much braking power that regen represents, that also depends on the specific setup. If you have a motor and controller that can generate high regen currents, and a battery designed to take them, then that could be quite a lot of braking power--with the right controller, motor, and battery, it could be at least as powerful as the mechanical brakes.
Suddenly losing that could be quite the surprise to the rider, and reaction time can be increased in those types of situations.
As an example, I depend primarily on my electric braking from the rear wheels to slow and stop my trike. My front mechanical brake can also do it, by itself, but I use it mostly in situations where the electric braking isn't appropriate for one reason or another (mostly when I want to slow very gradually, or I want to hold the trike in place, like waiting at a traffic light, etc.
My electric braking is two different systems, with "EABS" powered braking on the left wheel, and "standard' regen braking on the right wheel. The current output from the regen is slightly higher (a few amps) than that used up by the EABS, but the EABS has higher braking force (enough to cause brake steer to the left). Neither is adjustable/proportional, just on/off, and both are tied to the same ebrake lever (that has no other function).
I have no BMS on my EIG NMC packs, but some long time back when I was still working out all the wiring, I had an issue a few times where electric braking would suddenly stop happening, because the main battery disconnect switch/breaker had a connection problem, The controllers and the CA would shutdown, and all motor power and electric braking would cease. Mostly this happened during acceleration, under the highest load the system would see, which was annoying (and even dangerous a couple of times), but when it appened under braking it was qutie a surprise the first time. Thankfully I had plenty of time to recover from it and use the mechanical front, but there are traffic situations in which this is not the case, where someone suddenly swerves into the lane in front of me (because I'm significantly slower than the rest of traffic on the road, so there's almost always a large gap in front of me.
Of course, a cotnroller or other failure could also cause loss of regen braking, so this kind of sudden braking loss / failure is not just possible from a BMS shutoff; that's just the only scenario I mentioned as it's relevant to this discussion.
One situation in which the (front) mechanical isn't much use is in our very infrequent heavy rains, when it's just started, and the surfaces of the road are oil-slicked. The brakes work fine, but the wheel much more easily locks up and then just skids, and I then lose control of steering with no traction on the front. The electric braking is on the rear, and is very efective in the same situation, even though it's always applied fully and suddenly, partly because it can't lockup the wheel (but it *can* slow me very quickly). If I lost the electric braking in that kind of situation, the mechanical front wouldn't be able to take over the same job.
(FWIW, on my bike, it has electric braking front and rear, as well as mechanical front and rear, and in the same situation I could use the mechanlcal rear to take over if electric failed, The trike doesnt' have that option yet. (will someday)).
This used to happen on an old EMS E+ bike I had. It was a non-issue.
I'd venture thats' the case on most bikes/etc. Just not on all of them.
Agreed. It would take a very long descent to get voltages high enough for a fire.
That might depend on the electric braking setup; if it can generate very high voltages (without blowing controller components) currents could be higher and battery voltages could get higher; whether that's enough to cause a fire depends on the particular chemistry, I guess.
But most likely it would only happen on quite a long descent right at the start of a trip before much, if any, battery charge has been used up.
(I don't remember what results there were from such situations, but I recall discussions of this specific problem with various chemistries on DIY Electric Car forums almost a decade ago or so when I started learning EV stuff. Might've only been theoretical rather than situational discussions--cant' remember. I was going to check stuff from that era, but that forum won't let me log in for some reason.
However, regular overcharge at slightly higher voltage encourages dendrite growth, and this leads to battery fires eventually.
True, but it's easier to prepare for that eventuality (design of battery containment, location of bike or vehicle parking/storage, etc) than any kind of sudden issue on the road in traffic.
