miro13car wrote:there is problem here.
If you built prototype why do not post pictures of prototype , why AutoCAD dreawings??????
Philistine wrote:If you guys could show an actual physical prototype....
dpearce wrote:Well we finally have a price for you guys, it will be $1450, or $1300 for ES members...
Prototype 1 was carbon fiber... Did you happen to see read the first post, click on any of the links?
Philistine wrote:Yes I saw that link and I had read that thread at the time, but that frame is a monocoque carbon frame, it is totally different to the proposed frame, and so what I am saying is I would be interested in seeing photos of a physical prototype of the proposed frame.
Spacey wrote:Just to clarify...what would you get frame wise for the money? Front shocks included or just frame and swinging arm? I'm just looking into the feasibility of a certain project over here in Europe.
danimal wrote:The frame is constructed of TIG welded chromoly that has been precision waterjet-cut, making a capable light weight and versatile frame. It has been designed to hold the batteries low and centralized.
Alan B wrote:Question 3 is the more interesting one. Hopefully they have a prototype soon to answer it.
Danimal, Any rough idea when you will have these in production? And do you have a finalized design yet?
Also, will you offer them without the swing arm? Or build a custom swing arm? The wheel I have in mind won't fit a standard swing arm
Have you investigated shipping costs yet?
1) Please explain why you switched from light weight carbon fiber composite to heavy Crmoly?
2) Did the carbon fiber prototype have any issues in the design, construction, or durability in field testing?
3) What is the total weight difference between these two bikes when using same weight components & parts using Crmoly vs Carbon Fiber?
dpearce wrote:However it is designed to use mountain bike suspension, which all together is about 18lbs lighter than the heavy motorcycle suspension used before.
Users browsing this forum: No registered users and 2 guests
