Tesla Buys Nearly 2 Billion Panasonic Cells
Topics related to EV businesses
TheBeastie
Re: Tesla Buys Nearly 2 Billion Panasonic Cells
Post by TheBeastie » Nov 21, 2013 8:09 am
The thing I dont get with Tesla going Panasonic is that from the tests that a guy was doing here on ES the Jap cells were crap and the Korean LG/Samsung cells were heaps better.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles range http://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Beware of dodgy 18650 cells! youtu.be/eOshOXcSkDA
Consider PAS as your only throttle http://goo.gl/m17J9j
CO2 is core to Photosynthesis https://youtu.be/t5mvDONB6FI
Check out the Bill Gates nuclear reactor https://goo.gl/Rtky9q
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
ricklearned
Post by ricklearned » Nov 21, 2013 11:05 am
TheBeastie wrote:The thing I dont get with Tesla going Panasonic is that from the tests that a guy was doing here on ES the Jap cells were crap and the Korean LG/Samsung cells were heaps better.
Tesla has modified th chemistry and one can't make the same comparison with cells purchased in the market. Only the form factor is the same.
liveforphysics
Post by liveforphysics » Nov 21, 2013 4:12 pm
Tesla has modified th chemistry and one can't make ths same comparison with cells purchased in the market. Only the form factor is the same.
The modern Panasonic NCA cells are as good or better than anything.
ricklearned
Post by ricklearned » Nov 29, 2014 11:07 pm
liveforphysics wrote: .........
No doubt the Panasonics cells are good, but unless you are comparing them to cells out of a Tesla that statement has no value to me.
liveforphysics
Post by liveforphysics » Nov 30, 2014 4:33 pm
It took me 4 tries of just ordering Panasonic's older PD cells before I finally got legit ones. There are way more knock offs out there for sale than legit cells. Impossible to tell a well done fake from genuine from appearance.
fechter
Post by fechter » Nov 30, 2014 6:09 pm
I'd like to see them take like a billion of those cells and put them in series end to end in a large circle until the ends get close enough to arc. How far can 4.2 billion volts jump? :twisted:
liveforphysics
Post by liveforphysics » Nov 30, 2014 6:19 pm
fechter wrote:I'd like to see them take like a billion of those cells and put them in series end to end in a large circle until the ends get close enough to arc. How far can 4.2 billion volts jump? :twisted:
Tesla said once you gain the potential to contact the ionosphere, you get your arc capable of reaching anywhere on the earth. I would assume 4.2BV would be more than adequate.
Ykick
Post by Ykick » Nov 30, 2014 6:35 pm
OMFG, that's well worth reading again and again...
Talent must not be wasted.... Those who have talent must hug it, embrace it, nurture it and share it lest it be taken away from you as fast as it was loaned to you.
- Frank Sinatra
nutnspecial
1.21 GW
1.21 GW
Post by nutnspecial » Mar 19, 2016 9:08 am
Thinking a little further, a single lightning bolt is thought possible to contain over 1 billion volts and several billion watts, although I'm pretty sure that must be a guess?
Here's some really informative facts and Q&A from a few sources:
http://www.aharfield.co.uk/lightning-pr ... -lightning
http://hyperphysics.phy-astr.gsu.edu/hb ... ning2.html
http://www.nssl.noaa.gov/education/svrw ... tning/faq/
Also some wild documentation-
https://www.youtube.com/watch?v=RfgkFyEWQaY
https://www.youtube.com/watch?v=Wi6kIpqmuak
Punx0r
10 GW
10 GW
Post by Punx0r » Mar 21, 2016 11:59 am
The dielectric strength of air is 3.0MV/m so 4.2GV could jump a gap of 1400m (nearly a mile).
