ebikessf.com recommendation?
Topics related to EV businesses
wallypedal
Post by wallypedal » Mar 17, 2016 8:37 pm
Several months ago, I corresponded with ilia about the unique needs we have for an e-bike based attachment for my son's wheelchair. We are about ready to take the plunge and order motor, controller, cycle analyst, battery and a couple other things as a package from him. We know that perhaps some of the components are slightly lower cost elsewhere - but we are interested in a package that will be supported from a reputable vendor.
Any reason for us to hesitate or have concern? This will be a high torque gear motor set up to run 48 V, using the controller he has in the package. I don't think I have read anything but good about them in the past.
Thanks, all!
Wallypedal
teklektik
1.21 GW
1.21 GW
Re: ebikessf.com recommendation?
Post by teklektik » Mar 18, 2016 12:57 pm
Not exactly sure what you are looking for here, but Ilia is a stand-up guy who supports his products 110%. Very knowledgeable and helpful. See my build in the signature that uses two BMCs from him. His wheel builds are excellent and last a really along time without truing or spoke maintenance. If you need a smaller wheel for some kind of clamp-on wheelchair contrivance, I'm sure he can accommodate you - even if you drop ship a rim to him.
As far as the gear motor kit is concerned - you didn't specify which, but the BMC motors Ilia carries are well made with outboard double-lipped seals on the shaft and a very good gear/clutch assembly. That said - the motors are expensive and the gear clutch replacements are pretty costly. If you ever need to replace the clutch, it's worth noting that off-the-shelf MAC clutches from EM3EV fit nicely and perform the same. The BMC, MAC, and the eZee motors share a common heritage and so some parts can be swapped...
Get a CA V3 - completely different animal than the V2. I would also get a CA 3-position switch from ebikes.ca (if Ilia doesn't carry them) to go with it (this is not the same device as a controller 3-position switch). I'm not sure if Ilia's BMCs have temp sensors in them these days, but if they do, the V3 can display the temp and back down the power to prevent overheating. The throttle adjustment to eliminate dead zones and throttle ramping to take the stress off the clutch make this a no-brainer for an extra $20.
oatnet
Post by oatnet » Mar 18, 2016 2:40 pm
I'll 2nd that. I've purchased from Ilia many times, and sent dozens of people his way. Purchase with confidence.
-JD
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
80for20
Post by 80for20 » Mar 20, 2016 8:53 am
I bought a Schlumpf HSD from him in 2014. He was wonderful to deal with. It was an angsty process and he made it super smooth. Very responsive.
adam333
Post by adam333 » Mar 31, 2016 1:16 pm
I bought two Schlumpf HSD from Ilia, he was very helpful and the transaction was smooth. I would definitively buy again from him.
lester12483
Post by lester12483 » Apr 04, 2016 4:36 am
ebikessf.com are very reliable in my opinion. I have purchased from them in the past.
MT6 Hybrid- Electric Bicycle 48V
48V 23AH AllCell Lithium Manganese Battery Pack
http://www.chicagoelectricbicycles.com
