New Tire Link:
http://www.conti-online.com Continental Tires
Expanding Search to Motorcycle Rims:
As an alternative, decided to open myself up to more options as I began to have some serious concerns about having enough choice between rims and tires. The gating factors being: Diameter, Width, Aspect Ratio, Hole Count, Product Type/Usage, Quality of Workmanship, Reputation, Price, and Availability. Failure to meet criteria of any one of these attributes could sink a potential match. Here are some motorcycle rim manufacturers/suppliers that I reviewed:
http://www.mooseracing.com Moose Racing Rims (this official site is lame, so Google a supplier)
http://www.rkexcelamerica.com/mx_excel_rims.html Excel Rims (so is this one; other retailers do a better job)
http://www.prowheelracing.com/products/mx/rims Pro Wheel Racing Rims
http://www.buchananspokes.net/categorie ... l_rims.asp Buchanan's Rims; supplier of several types - including bare, unpunched rims for custom orders. Spendy!
Suppliers:
There are a lot of sites out there to help us find the proper tires and rims. The problem that I had with many of them is that they want us to provide the make, model, and year of the motorcycle/scooter before offering a selection which in my mind is ass-backwards if I already know the diameter, width, hole-count, etc. Google, TheFind, Amazon, eBay, and their ilk were of limited value, and often frustrating as a utility when attempting to craft a proper search string. One gem though stood out…
Picking a Favorite:
I have decided upon the Continental Conti-Go! 2.75-18 M/C 48P TT (70-457) tyre mounted on an Excel Takasago 18x1.85 (457-47) 36h Rim. I will leave the front and rear to be the same since I am crafting a 2WD bike.
I cannot begin to explain the challenge here in attempting to match a tyre and rim – it was a struggle until I found the very last link Pneus-Online***.
Why Continental:
I have close to 9 months experience running the Continental Contact Reflex both F and R on my current e-build; they are adequate and give me little trouble. That ended up weighing in during in the process of removing unknowns from the calculus. There are some great manufacturers out there, but most of what they offer is difficult to source, and if it is found – pray it doesn’t cost your next-born child. The Continental Conti-Go appears to be a decent modern all-weather road tire, though I will need to pick something else for snow or off-road.
Continental Conti-Go! New City tyre for light motor bikes.
Why the 18†Wheel Size:
The Excel 18â€Â/457mm rim when combined with the 2.75â€Â/70mm wide tire (and similar aspect ratio) should not exceed a total diameter of 24â€Â/610mm - thus meeting the criteria to drop the overall bike height by at least an inch/25mm. Presently I have the Mavic EX 729 Disc Rim with the Hookworms pegged for install - effectively setting the wheel diameter to 27.5â€Â/700mm and exacerbating the already tall-for-a-medium-sized frame (it’s a Felt-Compulsion 1). Then I added Marzocchi 888 RC3 EVO DH forks which will raise the height even more.
As for why I picked 18†over 17†or 16â€Â, I just thought that it might look a little odd if the tires were too small. The other problem is that the rear suspension framework is too narrow to load a 3â€Â-wide tire; even if the diameter was smaller there’s just not enough room. Once I gave up on the 3â€Â-wide tire idea another struggle ensued to find any tire narrow-enough to fit.
The last factor was based on selection and availability: There simply is not enough choice, and that can be easily proven by using the Pneus-Online*** website. U.S Domestic supplies are limited: I had to go look across the pond to Europe before I finally found the tyre.
The 1.85â€Â/70mm-wide x 18â€Â/457mm diameter Excel motorcross competition rim, being machined from lightweight 7-series aluminum, is stronger than any bicycle rim, and as a 22†equivalent-bike size - it falls neatly between the 20†and 24†inch gap. Trivia: This size also called an ISO457mm standard, 22x2.125, and 22x1.75, …and impossible to reliably find in bike-size.
Excel Takasago Signature Series Rims, available in several colors.
Caveats:
- There is lots of poop about the Excel rims needing their own spoke kits; another work item.
- Need to source a tube and rim-liner as well.
- Then figure out how to get the tires balanced.
<pause to graze, looking for something to nibble on…>
Conclusions:
Q: Rhetorically, can we find and mount a 16â€Â/406mm motorbike/scooter tire onto a 20†BMX wheel?
A: Yes, certainly. For example, mounting the Continental Conti-Go! 2.75-16 on say a Bombshell BMX Revolution Pro 1.75†Rim would create a wheel that drops a standard Mtb frame by more than 2 inches; a viable solution – it’s lighter, less expensive, more bike-like, and exceedingly meets the criteria.
My choices however are constrained by many factors, beginning with the narrowness of the frame. Picking a slightly larger rim expands the selection, raises the load characteristics and the top speed, and I end up getting a more durable pairing.
In the end, I guess one could say “if you look hard enough, you will likely find what you’re seekingâ€Â
…or maybe it will find you.
Trouble always finds me; no need to look that.
Thoughts? KF
