this is by way of a sister thread to the thread knuckles is doing on the infineon controller techecnical thread.
This thread Is aimed at showing just what the infineon can do with the advanced options.
tests are being done with a Puma motor under no load, when these tests are compleat I will start on load tests, since they are all no load they are of use because they relate to the other tests done on the same motor at diffrent "speed" and voltage settings this is not so much a comparison to other motors or other controller as within this motor controller setup.
First have a read of a pdf I wrote on the infineons advanced features.
