Crystalyte Controllers - Repair and Modification information
Archive of useful information. This is not a discussion area.
Re: Crystalyte Controllers - Repair and Modification information
Postby mikereidis » Thu Sep 04, 2008 4:26 pm
pwbset wrote:
mikereidis wrote:Aren't these 6 additional FETs under the board?
Heatsink I believe. I'm looking forward to seeing if you have some success with your project.
Ahh, OK, thanks. :idea:
I thought they looked a little flat and plain. The screws and the tight space fooled me. :)
So it has the minimum of 6 FETs, 3 high and 3 low. All is right with the world now.
mikereidis
Postby mikereidis » Fri Sep 05, 2008 9:14 am
mikereidis wrote:I checked the hall sensor holes 2 days ago to confirm for myself it matches C1246 pinout:
A: goes to pins 1 and 4
B: to 3 and 6
C: to 2 and 5
So it appears to me it differs a bit from the schematic you show for 40a version. Instead of a voltage divider giving about 5 volts on negative side of comparators, these hall sensor lines seem to be setup in a differential mode. Perhaps this gives better EMF/noise immunity ? BTW, to hookup I used a few feet of cat5 network cable with 4 twisted pairs and each hall sensor pair is ground and sensor twisted.
Hall sensors need pullups ? If so, I'd think they'd be on the board. I will check.
If the immediate start version still has those BEMF sensing resistors, then I'd hope there was some way to disable them (or just disable their connection to C1246) without removing/destroying them. There MUST be a jumper somewhere or I won't be entirely happy. Would be nice, but not essential, if pedal first still worked if one or more of the hall sensors go bad.
Yes, halls need pullups. :) I tried some random 1-5K resistors pulled up to +5v but didn't work. Interesting observation: once I fixed one bad hall connection solder joint (insulation in hole ! My eyes aren't so good no more), then the pedal first still worked with the halls connected, with or without pullups. So at least it doesn't interfere (but does if one hall line breaks ?).
This didn't give me instant start however. I still think that no matter the combination, the motor should do something, even if just a growl or a bang or two when throttle twisted. Spinning the wheel a little will give all 6 combinations of 3 halls and at least one or two of those should make some noise.
Is pedal first minimum start speed enforced by a minimum AC voltage produced by motor ? Or does something measure pulse frequency to set the min start speed ? I think, at least, I should be able to replace BEMF sensing with hall sensing and have a hall driven pedal first setup. (I'm assuming I can make the phase offsets correct.) Once I do that, I can look for what to mod to reduce the start speed (to 1 KMH say, real easy to do) or eliminate the need for prior rotation.
I traced the connections to those 6 BEMF sensing resistors. The tap between them connects directly to the hall sensor holes and the comparator pins on c1246. Pins 1 and 4 are both negatives, 3 and 6 are both positives and 2 and 5 are one of each.
Each top resistor (I measured 38Kohms) goes directly to motor lead. Each bottom resistor (13Kohms) goes to negative bus/ground. So it seems like a simple 25% voltage divider, although probably more complex than that since 3 phase AC comes in here, and it's relative to all 3 phases, and not really relative to the negative bus/ground.
I could use the top resistors as pullups, and cut traces or whatever to disconnect them from motor. But it would be REALLY nice if I didn't have to cut components or traces, and still leave BEMF sensing there as a full time non-interfering thing, or switch selectable.
So I'm off to read C1246 app notes and learn what I can to go farther.
EDIT: Dagnab it ! The notes are in Japanese only: http://www.necel.com/cgi-bin/nesdis/o00 ... le=UPC1246
http://www.necel.com/nesdis/image/IEP-651.pdf
http://www.necel.com/nesdis/image/IEP-653.pdf
Datasheet is available in English but I already have that. Anyone know of English app-notes for this chip or very similar chip ?
mikereidis
Re:
Postby ejonesss » Tue Sep 09, 2008 2:16 am
The7 wrote:The original 48V IS controller has an LVC at 29V.
The 33k and the R6(5.1k) will be removed to de-activate the LVC so that the controller will work from 24V battery to 48V battery for my AL1020 ebike.
i was wondering can the lvc be bypassed all together to allow 12 volt operation or even use of ni cads (witch has no problems with over discharging in fact requires complete discharging to prevent memory) just by jumping a wire from the bat+ to the resistor/diode junction? (basically shorting out both resistors)?
stuff for Even Newer 4 to 24-cell Battery Management System (BMS)
32 lifepo4 cells 16s2p 40138 green cells √
16s2p 40138 based pack built assembled (building electrical equiv to $2000 eonyx system.*
ejonesss
Re: Re:
Postby fechter » Tue Sep 09, 2008 8:38 am
Yikes! don't do that.
If you want to disable the LVC, you could disconnect either the diode or disconnect R6, whichever is easier.
12v might be pushing it since the voltage regulator is trying to make about 14v and needs a little more than that for voltage drop. It might work however. For 12v only, you could possibly bypass the voltage regulator.
fechter
Postby ejonesss » Wed Sep 10, 2008 3:33 am
i havent looked at the controller closely but the only voltage regulator there may be (typical of many electronics) is a 7805 to make the 5 volts for the logic power.
ejonesss
Postby fechter » Wed Sep 10, 2008 8:21 am
Right, there will be one of those too, but the FET gate drivers, PWM chip and commutator all run on 14v. 12v would be fine. In the normal application, there is a linear regulator to drop the battery voltage down to 14v, then the 7805 drops it down to 5v for the throttle and and some of the voltage references.
fechter
Re: Re:
Postby ejonesss » Thu Sep 18, 2008 9:06 am
looking at the picture i could not find the diode you are talking about.
can i just connect pin 2 to ground (- terminal of battery)?
ejonesss
Re: Re:
ejonesss
Re: Re:
Postby fechter » Thu Sep 18, 2008 9:23 am
ejonesss wrote:looking at the picture i could not find the diode you are talking about.
No, that will disable the current limiter too.
I think the diode is on the bottom or something. Just remove R6.
Brushless Controller disable LVC.jpg (87.5 KiB) Viewed 2111 times
fechter
Postby ejonesss » Thu Sep 18, 2008 11:24 am
what about applying the 29 volt lvc hack to the 300k resistor (looks like 1 volt per k of resistance so in theory it shourl be 9 or 10 volts )
the thing is the controller is still under warranty until november (witch fall will kick in and the weather will be too cold to ride).
if i can just jumper a resistor i can make a jumper on 2 alligator clips that i can clip onto the resistor and once the tests are done i can remove the clips and electricrider.com should not be able to detect tampering if anything goes wrong.
i did apply the abs wire for the regen so i can try out the regen braking and i simply took a piece of wire and poked it into the abs hole and did not solder it so if the controller fails requiring warranty work i can just pull the wire out and electricrider should not void the warranty.
at $250 a piece i would like to not have to pay a $75 diagnostic fee+ any repairs.
i want to find out how low i can take the voltage and still have hill climbing power because with lifepo4 batteries being so expensive i maybe able to trade off voltage for more amp hours.
ejonesss
Postby fechter » Thu Sep 18, 2008 2:34 pm
ejonesss wrote:what about applying the 29 volt lvc hack to the 300k resistor (looks like 1 volt per k of resistance so in theory it shourl be 9 or 10 volts )
Yep, that should work.
fechter
Postby ejonesss » Thu Sep 18, 2008 2:56 pm
i just opened up the controller and i just realized it is version 2 looks like the one
viewtopic.php?f=2&t=764&st=0&sk=t&sd=a&start=210
and
download/file.php?id=11553
if the picture does not load then copy and paste to view it
witch means the chip is surface mount and the resistors are not along the edge of the board making warranty voidless work more difficult so i guess i will have to bite the proverbial bullet and hope electric rider does not actually open up the controllers or it does not fail requiring repair.
ejonesss
Postby ejonesss » Thu Sep 18, 2008 6:27 pm
a final update:
it turns out that disabling or lowering the lvc to allow running on 24 volts or even 12 is not going to work.
you lose torque and speed on the lower voltages. so for me at least i will have to put out the $700+ for the 48v 20ah lifepo4 battery.
however there may be still a good reason to lower the lvc would be if you want to get started in electric biking and the dealer does not have a specific controller and you are forced to have to buy a 7248 controller for example but you dont want 6 batteries you can lower or disable the lvc and run it from 48.
ejonesss
Postby rkosiorek » Sun Oct 19, 2008 7:53 pm
there is a separate thread for the V2 controller. it uses a switching regulator to drop the battery voltage down to 15V to run the FETs and drivers.
this regulator is made from discrete components and the schematic for it is on page 1 of the V2 controller thread.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=3896&start=0#p57595
just for a lark i hooked it up to a lab supply and scope. i found that the 15V switching regulator would stop working at around 16-17V so the lower limit of this controller is 17V if this regulator circuit remains. if you do want to use it at 12V this regulator would have to be bypassed. the question remains how llow a voltage will the FETs and drivers switch at. remember that a 12V nominal battery will sag to less than 9V under heavy load. will the controller still work there? i have some doubts and reservations.
The LVC circuit is about halfway down page 2.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=3896&st=0&sk=t&sd=a&start=15#p58887
if you want to lower the LVC down to 17V just change R15 to 3.9K
hope this helps.
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby rkosiorek » Tue Oct 21, 2008 2:26 pm
back on page 1 fechter posted a circuit to allow you to adjust the current limit between 20% and 10% of the upper limit set by the shunt circuit.
i put one together and put it into a plastic box with a clip to mount it on the handle bar. i put the contol pot on the rear panel. on the front i have a NC pushbutton switch. the switch is just wired in series with the wiper. so normaly the wiper would be connected through a 150K series resistor to pin 1 of the PWM chip, just like in the schematic. so normaly the current limit is set by the control knob. when i push the buton however the control is disconnected and the full power set by the shunt is available.
works sort of like a TURBO switch whan i need full power for a few seconds. having it mounted on the handlebar within reach of my thumb just makes it so conveneint.
Rear Panel
Front Panel
Handle Bar Mount (removed from a cheap bell i got at the dollar store)
DISCLAIMER:
rkosiorek
Postby marty » Tue Dec 09, 2008 9:40 am
Question about heat? Got Crystalyte 36V 35A Start Immediate Analog Controller. Using 48V battery. Took it out of case. See Fechter's picture.
controller and case
Note the white thermal joint compound between aluminum block and aluminum case. Been testing with bike mounted in stand. Do not notice controller getting hot or warm. Plan on putting controller in new water proof box. Do I need to worry about heat? Should aluminum block be mounted tight to new aluminum case with thermal joint compound? Or can I use a plastic case and not worry about heat?
ebikes.ca
Online resource for electric bicycle conversions
http://www.ebikes.ca
MARTY
Volt Electric Vehicles
http://www.voltev.com
marty
Postby fechter » Tue Dec 09, 2008 9:54 am
On a stand, the motor does not draw enough current to make much heat. On the road is another story. The heat is significant and needs to go somewhere.
An aluminum box would be ideal. Another approach would be a plastic box with a large square hole cut in one side where you can mount an aluminum plate. The plate can be sealed to the box around the edge to make it waterproof, but have the aluminum exposed to the air for cooling. Attach the controller block to the inside of the plate. If you attached some cooling fins, size of the plate could be reduced. The block itself could be used for the plate if you can get all the heat sink goop off good enough for glue to stick to it and you plug all the holes with silicone.
fechter
Postby marty » Tue Dec 09, 2008 11:02 am
Thanks Fechter,
The new water proof controller box will be aluminum. Thinking about a air vent so it will dry out if water does gets in.
ebikes.ca
MARTY
marty
PreviousNext
Return to Technical Reference Area
Who is online
Users browsing this forum: No registered users and 3 guests
