Definitive Tests on the Heating and Cooling of Hub Motors
Jestronix
Re: Definitive Tests on the Heating and Cooling of Hub Motors
Post by Jestronix » Dec 30, 2017 7:08 am
I'm sill amazed to this day that mxus etc don't make a from factory heatsinked hub! With a researched design for capturing maximum airflow. Makes me think most hubs are built for the China market?
I'm going to look at heat sinking the side covers, however just my simple mod has almost cured my main heat concerns. I only hit high 90s on my climbs today, however I'll by moving towards 10kw on a smaller diameter moto rim.
amberwolf
Post by amberwolf » Dec 30, 2017 2:00 pm
Cowardlyduck wrote:
Dec 30, 2017 5:51 am
They apparently push 5.13CFM each, which is pretty impressive for a 25mm fan:
But I'd bet thats' only wiht no obstructions in front or behind. Put a dust filter on either end and I doubt you'd get much airflow (lot of noise though).
DasDouble
Post by DasDouble » Dec 30, 2017 3:12 pm
I have asked because that´s the only thing which keeps me away from drilling some easy holes inside the side cover as I don´t want the motor to get damaged by stuff like dirt etc... :roll:
Highpower Ebike enthusiast.
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
Bullfrog
Post by Bullfrog » Dec 30, 2017 3:42 pm
Assuming you are running a Direct Drive motor, I'd suggest you use ATF or Ferrofluid to conduct the heat to the case and then use a ducted fan (without a filter) to blow air over the motor. All of the things that work with a Direct Drive motor also work with an Internally Geared Hub Motor they just have to be applied appropriately.
Adding sinks (fins) and spraying a mist of water on the sinks when the motor gets hot will give you additional cooling.
If it were me, I'd first add fluid to the motor to thermally connect the motor to the housing, second I'd add sinks, third I'd add a fan and/or water misting.
Going to a smaller wheel will increase the motor efficiency and the way you ride can be a factor...try not to use full throttle at very slow speeds and never use your brake and your throttle at the same time. Your motor is most efficient at the rpm it attains when you pick the back wheel up and hold the throttle wide open. At rpms less than that it is less efficient and produces more heat. This is a broad general statement with a lot of caveats.
You can make the problem of heat rejection extremely difficult or very simple....keeping it towards the simple end should make it more reliable and less expensive.
A lot depends on the environment where you ride....I ride off road in the dirt and dust 100% of the time.
If you are going to ride on the pavement in a relatively nice clean environment, then cutting holes in the housing WILL help cooling. But, there is always a but...then you can't use ATF or Ferrofluid and you will always get some dust and dirt in your motor.
Only you can decide what is best for you and the way you want to ride.
DasDouble
Post by DasDouble » Dec 31, 2017 5:24 am
Yeah I see, I already have ff and the hubsinks. I could now theoretically add another pair of hub sinks, that could help too..
Another question: Do you guys think, or maybe someone already did that, that some more CPU fans, placed on the whole sideplates of the hubbie could help cooling the motor? Did someone already tried that?
-Built own ebike: ✔
Bullfrog
Post by Bullfrog » Dec 31, 2017 8:11 am
More sinks will help.
One suggestion is to use an infrared thermometer to measure the surface temps of your motor and find the hottest area and direct the fan or fans toward that area. Also if you position the fans slightly forward and direct them aft, the velocity of the fan is added to the velocity of the bike...if you point them entirely left or right then you don't get the additive effect. In theory more fans would be better but I can't guarantee it...best way to find out is try it. Theory and reality don't always agree :D .
If anyone hasn't seen it, the Grin Tech web site has some good info on ferrofuluid, how much to use, and how much it helps. Their motor simulator is a good tool as well and it has the capability to model with and without ferrofluid.
Probably the best way we can all benefit is if everybody will post what they have done and the results. One experiment is more valuable than all of my hypothesizing.
DasDouble
Post by DasDouble » Dec 31, 2017 9:19 am
Well I have posted it someowhere before I think but here again my results:
Faster cooling while standing still with ff and hubsinks then without.
I have 8 ml ff inside. Some folks said 5-7 would be the best for the QS 205V3. More would add some resistance between hub and outher shell.
-Built own ebike: ✔
Bullfrog
Post by Bullfrog » Dec 31, 2017 10:38 am
Good info, thanks.
Where did you buy your QS motor and the sinks and what is your opinion of the QS motor? This article makes the QS205/50H V3 sound like it is the best option: https://www.electricbike.com/large-hot-rod-hubmotors/
I may try one at some point...just FYI, EM3ev may start carrying them in the very near future. They have been good to deal with on my BBSHD and my MAC but I am having a little trouble getting a battery problem resolved.
I currently have one bike running a MAC IGH motor and I had to use 3.5 ounces (104 ml) to maximize my cooling. Any more than 3.5 ounces in my motor and I would start leaking...a lot smaller diameter than most DD motors and a bigger gap between the motor and the housing. Running a BBSHD on another bike. I ride off road 100% of the time so the weight of a big DD is tough to swallow at this point.
DasDouble
Post by DasDouble » Dec 31, 2017 1:44 pm
Got the ff from merlin, the QS from Artur and the hubsinks from Sketchism. Well I can´t tell a difference between the QS and other brands as I have only experiences with the QS.
So you mean you have a liquid cooled motor? Awesome :D
-Built own ebike: ✔
Bullfrog
Post by Bullfrog » Dec 31, 2017 4:54 pm
Well I guess the motor is liquid cooled :) but the case is still air cooled :( .
Haven't had a chance to run it much due to a battery problem that is currently being worked between me and EM3ev but my initial testing showed that the ATF helped a lot. My MAC came prewired with temp sensors and I am running a Cycle Analyst to display the temps...the section that used to get my motor to 105 C now gets it to 83 C so the ATF works great for my particular application.
Jestronix
Post by Jestronix » Jan 02, 2018 6:37 am
So impressed with what a simple fan mod has done, I moved to a smaller fan and got the same/ similar results and reduced weight so slightly :) I also found running the fan all the time gave the best results, rather than when things get stinking hot, eg 70c up.
Be great to see some results in Justin's test rig :) with hub sinks too :)!
Bullfrog
Post by Bullfrog » Jan 02, 2018 4:15 pm
Everybody needs to remember that Jestronix is running a fluid (can't remember if it is ATF or FF) which thermally connects the motor to the housing.
Without the fluid, I don't think the fan would help nearly as much.
DasDouble
Post by DasDouble » Jan 02, 2018 4:43 pm
So thats the next step further from now on? First ff, then hubsinks and then active cooling by a fan? Awesome, I like progress :)
-Built own ebike: ✔
markz
10 GW
10 GW
Post by markz » Jan 02, 2018 6:22 pm
More aluminum mass on the inside, heat sinks between the flanges, ferrofluid, pc fan then the last resort would be drilling holes.
You could add the alum mass yourself, balancing it all out.
DasDouble
Post by DasDouble » Jan 03, 2018 5:16 pm
Well my friend, you have just brought some crazy good idea right there...! More aluminium mass on the inside.. Why did I not came to the same idea some earlier? Not only on the outside, but the inside also! Crazy good idea, crazy good.. :!:
Cheers
-Built own ebike: ✔
