zukster
Check out these pics. IMO, I think its safe to say that if you're going to try to run the
Bafang SWXH 26 Inch wheel model on the bigger Ecrazyman controller, you better use extreme caution.
Maybe on a smaller wheel, you'd fair better. Mine is a 26 Inch Wheel.
My original post on testing this is here http://endless-sphere.com/forums/viewtopic.php?f=2&t=10042
The unbaked motor was run with the 36V/350W Controller on 40V 12AH and 60V 18AH Canadian Tire 20V
Yardwork battery packs in Series. I ran it for a couple of weeks without problems until the hall sensors failed.
Then I switched to a new motor with the same battery packs and the 48V/600W Controller. The motor has
been overheated twice now - doing roughly the same driving (with and without a trailer for both).
So if your going to go with the bigger one, you better make sure your batteries are up-to-snuff and maybe
even get a Cycle Analyst CA with the battery-controller-shunt that allow you to limit current.
