I just bought from EM3ev a Mac 8T w/cassette kit laced into a 20" wheel for my folding bike. I'd send these questions to them, but it is now the E-bikers (and RC'ers) favorite long-term holiday, Chinese New Year. So...
-I temporarily mounted it on the bike and plugged everything up and it all seems to work beautifully, except there is a faint squeal coming from the motor at very low RPM's, whether powered or just spinning it by hand without power, in either direction. It also doesn't freewheel very well. It almost seems like there may be a rubber seal in there somewhere that is rubbing against metal causing the squeal and resistance to freewheeling. Is this a problem, or is it just something that Macs do? None of the 4 other geared hub motors I've had experience with (3 Bafangs and an old brushed Heinzmann) have made a peep or had any resistance to freewheeling. This Mac spins up fine under power (without a load at least) and doesn't make any funny noises other than the squeal, but it doesn't seem right.
(Edit: Here's a video that I also posted later in the thread: https://youtu.be/WUXFtQd29mE )
-There is a threaded round spacer with 2 flats that is threaded onto the axle on the cassette side which sits mostly underneath the cassette body that was loose. I'm assuming that should be tight, right? It is ultimately the part that rests directly against the inside of the dropout. I tightened it up and it went in a few threads before seating, but still did stick out past the cassette body by a few mm which seems correct. That didn't affect the squeal at all so not related.
-Axle mounting width (OLD) with that spacer tight is still longer than 135mm... I don't have a tool that can measure that directly but I did measure my dropout width at 134.3mm with calipers and the dropouts have to spread at least a few extra mm to fit the motor (guessing 137-139mm). I thought this motor was supposed to fit 135mm dropouts? I feel like there should be washers between the axle shoulder/spacer and the dropouts but none will fit without spreading even a few mm beyond what they already are. Is this a problem?
-I thought the cassette was supposed to fit a 7 speed cluster, but there was an extra 4mm when I slipped on the Sunrace 11-34T 7 speed that I previously bought from Grin. It took a 4mm cassette spacer behind the cluster to allow the lock ring to tighten it up. This will work fine, but is this motor actually supposed to fit an 8 speed cassette or is this particular 7 speed narrower than the rest?
I can take pics and/or vid if needed but I'm hoping someone already knows of these things.
Any and all help will be greatly appreciated.
