http://www.rqriley.com/xr2.htm
$125 Carbon Fiber Cloth 3.5 yrd
$35 Vinylester Resin 1 gal
$65 Urethane Foam 4 x 8 ft x 2.5"
$25 Steering Housing 25" of 1.5 OD x 0.035 T6 alum.
$16 Bottom Bracket Shell
$25 Tandem BB Shell
$290 Total
The Long EZ is constructed primarily with foam (blue styrofoam, Divinycell, and polyurethane foam) covered in two types of fiberglass (RA7715 and RA7725) laminated with an epoxy resin system such as MGS L285, MGSL335, or West System (only certain types), or EZ-Poxy.
jag wrote:The Long EZ is constructed primarily with foam (blue styrofoam, Divinycell, and polyurethane foam)...
JS Tyro wrote:jag wrote:The Long EZ is constructed primarily with foam (blue styrofoam, Divinycell, and polyurethane foam)...
I'm surprised they used blue polystyrene foam - that stuff offgasses for some time and ends up forming a very poor bond with the resin/epoxy. I know a lot of boat builders who won't touch the stuff. Divinycell is specifically made as a core material and so are various polyurethane foams.
JS Tyro wrote:An expert can do layups without vacuum bagging that are lighter and stronger than vacuum bagged parts. However, that is quite a skill - you have to squeegee out the excess resin without messing up the layup. If you've ever worked with composites, you will know how tricky that is.
gogo wrote:That process combined with CNC shaping seems a killer combo. And think of how easy it would be to route the wiring and make integrated lighting.
Enclosed 3-wheeler anyone?
northernmike wrote:A PROPERLY bagged part will, by design, have less porosity, higher glass/resin ratio, and most importantly, much better wet-out and consistency than a roller and brush can possibly obtain.
jag wrote:How is commercial foam core done? Glass and resin on top of the foam, or is the foam simply glued into the premade plastic part?
I had a Hobiecat years ago, and noticed those were foam core hulls, but I doubt they made 100,000's by hand.
gerhardt wrote: thought about vacuum forming a Lexan nose cone and then applying a carbon fiber layer to the insided surface for strength and appearance. Has anyone done this?
JS Tyro wrote:I'm surprised they used blue polystyrene foam - that stuff offgasses for some time and ends up forming a very poor bond with the resin/epoxy. I know a lot of boat builders who won't touch the stuff. Divinycell is specifically made as a core material and so are various polyurethane foams.
Jeremy Harris wrote:I've never heard of, or experienced, the outgassing problem with the pink or blue extruded polystyrene insulation foam (the stuff specified for Rutan designs and the stuff I use in the main).
JS Tyro wrote: Once the fabric is on and smoothed out, they go over the whole thing with a squeegee - relatively stiff plastic, not cheap window cleaning rubber stuff. They press the layers down and squeeze out the excess resin.
JS Tyro wrote: I've also seen the results on finished kayaks and you couldn't tell the difference visually from vacuum bagging.
northernmike wrote:How can a squeegee compete with atmospheric pressure? There's physically no possible way it can conform to the shape of the part the way a flexible membrane can.
Let's see some destructive stress test comparisons and then we can apple-to-apple the issue.
Jeremy Harris wrote:True, the microballoons do reduce the epoxy shear strength, [...], if it's sealed up from the petrol.
12p3phPMDC wrote:http://carbonbent.bravehost.com/index.html
Users browsing this forum: Bing [Bot] and 6 guests
