by chuck » Wed Oct 07, 2009 7:22 pm
At a velocity of 3 mph you will need about .6 hp.
Weight = 450 lbs
slope = 16/100, using a^2 + b^2 = c^2 , skip the trig, use 16/101.27
velocity = 3 mph or 4.4 ft/sec
frontal area about 7.5 square feet
The force of drag is 1/2 (air density)(coefficient of drag)(Frontal area)(velocity^2)
Fd = 1/2(.00273)(.9)( 7.5)(4.4^2) = .18 lbs
The force of rolling on my bike is about 3 lbs using maxxis hookworm tires at 40 psi with about 450 lbs of weight
Fr = 3 lbs
The force of the hill is weight * corrected slope or 450 * 16/101.27
Fh = 71 lbs
Add the 3 forces to find the total force
Total force = 74.18 lbs
To find the power required at the pavement multiply by the velocity
74.18 lbs * 4.4 ft/sec = 326.4 ftlbs/s
1 horsepower = 550 ftlbs/sec
326.4/550 = .6 horsepower
To find the gear ratio.
I have a scott 24 volt motor, 1 hp at 3000 rpm peak effiency.
Use a 26 inch mountain bike wheel. Its diameter is 26 inches/12 inches,,,to get feet,,, = 2.167 feet
Its circumference is 2.167 * pi = 6.8 feet
at 4.4 feet/sec this wheel must spin at 4.4/6.8 revolutions per second or .646 rps
convert this to rpm by multiplying by 60
Wheel rpm = .646 * 60 = to about 38.8 rpm
The reduction ratio is the motor rpm / the wheel rpm or 3000/38.8
Reduction ratio = 77.36 to one
For a 2 stage reduction take the square root of the reduction ratio or about 8.8 reduction ratio per stage
3/8ths pitch or number 35 chain will handle .6 hp with a 10 tooth sprocket at fairly low rpms, not ideal, but about the only thing available. Sprockets of 96 tooth are commonly available, use the chain for the wheel reduction.
96/10 = 9.6 ratio for the wheel reduction, lets find the motor stage reduction
77.36/9.6 = about 8 to 1
A 3v v-belt will handle this power at above 95% efficiency. Do not use a 3L belt, they both fit on the same size sheave, the L stands for light duty. The v stands for industrial. Lets try a 12 inch sheave to get that 8 to 1 ratio. 12/8 equals a motor pulley of 1.5 inches, perfectly fine size for a 3v "premium" called a 3vx belt.
Now, we are real close to a final ratio of 77.36 to one
V-belts have a pitch ratio, subtract .05" from each sheave to get the actual reduction. 11.95/1.45 = 8.24 ratio on the motor.
Divide the 8.24 ratio into the total ratio of 77.36 to get the final ratio of the rear drive. 77.36/8.24 = 9.386
ok, I am pretty sure one can find a #35 pitch chain sprocket with 96 teeth at a reasonable price. To find the jack shaft sprocket, divide the wheel sprocket by the remaining ratio, ie 96/9.386 = about a 10 tooth sprocket.
The final ratio is (96/10) * (11.95/1.45) = about 79 to 1..
(79 - 77.36)/77.36 = about 2 % off, reduce your speed of 4.4 by 2% for peak efficiency,
Don't ask me to calculate the efficiencies of these drives, but, the chain will probably be about 90% efficient, the belt about 95%.
Take the horsepower of .6 and divide by the power transmission efficiency of about 85% or .85.
.6/.85 = to about .7 hp the motor needs to put out. The motor and controller as a combination are about 85% efficient.
.7/.85 = about .83 hp. This is what the battery needs to supply. Convert hp to watts. 1 hp = 746 watts
The battery needs to supply .83 hp * 746 watts = 620 watts
For a 24 volt system the amps are 620 watts/24 volts = to about 26 amps
I use agm batteries that have a reserve capacity of 135 minutes at 25 amps. I use a 24 volt system with 68 ah batteries.
My reserve capacity in hours is 135/60 = 2.25 hours.
At 3 mph * 2.25 hours I will travel 6.75 miles up your hill. The scott motor will be warm, not smoking hot, at this output.
chuck
