Doctorbass wrote:
Well an ebike DYNO seems to become interesting again!
Doctorbass wrote:Methods seem a great candidate to test that for us!
ZapPat wrote:This means that the dual hub motor bike is actually more efficient than the single when the load gets over a certain point, but less at light loads. Winding heat is one culprit for sure (I^2*R losses), but how much does magnetic saturation come into it, I wonder?
Drunkskunk wrote:I think Doc's right. Time to revisit the Dyno project.
I could build one in an afternoon I bet, but the software is beyond me.
Jeff at EV Bones wrote:If the electromagnets are saturated with
the flux density at near maximum, a further power increase will fall
off sharply. The only one I have solid experience in this with was the
Crystalyte 408. It saturated at ~1.8kW, and anything more put into it
was being dumped as heat. As we all know, heat is the bullshit
detector for efficiency. In my example that worked out as ~25A at 72V
= 1.8kW. But it could also be 37A at 48V = 1.8kW, or even 50A at 36V
= 1.8kW.
Toorbough ULL-Zeveigh wrote:to answer the original question, at full load the xlyte 4-series saturates @1.8kW.Jeff at EV Bones wrote:If the electromagnets are saturated with
= 1.8kW.
from post#19 http://groups.google.com/group/tidalforce/browse_thread/thread/b64253d8fd27b618#
= 1.8kW.
are equivalent in terms of saturation. Magnetic field is caused by the current, so should occur at the same phase current, independent of voltage. I guess numbers might correspond to battery current and voltage into the controller. However, to quantify motor saturation we need amps going out of the controller into the motor phase windings (which may be higher depending on the pwm duty cycle).Jeff at EV Bones wrote:25A at 72V and 37A at 48V = 1.8kW, or even 50A at 36V
jag wrote:I'm puzzled by the numerical claim that bothJeff at EV Bones wrote:25A at 72V and 37A at 48V = 1.8kW, or even 50A at 36V
Arlo1 wrote:I have build a dyno. Seen here http://www.youtube.com/watch?v=XdjQ445WoJw and as a mater of fact it will work for low power ebikes.
Arlo1 wrote:
Arlo1 wrote:As for most motorcycle dynos dynojet ect. alot of them have eddy brakes so they are a light drum that spins up easy and to add load for higher power bikes they use the eddy brake at a load percentage.
Users browsing this forum: davec and 11 guests
