Dropout Failure Experiements, and a call for Fork Donations
Re: Dropout Failure Experiements, and a call for Fork Donati
Postby Zesty Bonanza » Sun Aug 21, 2011 9:19 pm
When the Cannondale Headshok was tested, did you have to file the drop outs so the axle will fit? I have a headshok and it seems to fit only 9mm axles whereas the electric hub/wheel that I bought uses a 10mm axle. I am thinking of filing down the drop out so my wheel can fit in it and I will use both rev 2 and rev 3 torque arms.
Zesty Bonanza
Postby Hugues » Mon Aug 22, 2011 6:33 am
Good analysis thanks.
Am I right to say that with regenerative braking the problem could get a little worst as the torque applied would be in the other direction ?
thanks
Hugues
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby justin_le » Mon Aug 22, 2011 5:49 pm
Zesty Bonanza wrote:When the Cannondale Headshok was tested, did you have to file the drop outs so the axle will fit?
Correct. If any of the dropouts were less than 10mm then they were filed accordingly until the axle would just fit. This is pretty common with hub motor installations on front forks. Standard front axles are 9mm or 3/8" diameter, and the normal fork opening is 9.8-10.0 mm for a generous fit, but some are done tighter.
Justin
Big Dummy with 24" eZee front hub, 25A infineon controller, and 48V 10Ah LiMn pack
My website: www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs
justin_le
Postby John in CR » Mon Aug 22, 2011 8:11 pm
Hugues wrote:Good analysis thanks.
thanks
Hugues
Yes, the extra issue with regen isn't the magnitude of the force, but the repeated forces trying to spin that axle first one direction on acceleration and the other during regen. Over time it loosens things up, so check the axle nuts even more frequently, and be alert for an audible "tick" when you hit the ebrake, which indicates that axle is starting to move in the dropout.
John in CR
Previous
Return to E-Bike Technical
Who is online
Users browsing this forum: garfong, Google [Bot], hillzofvalp and 8 guests
