by mwkeefer » Tue Nov 24, 2009 3:40 pm
Dogman,
Earlier I noticed you relating your intended test to riding down a staircase of 16" stairs.
I can attest that i have ridden my 26" Hard Rock not only down the Philadelphia art museum steps but, I rode down after I had ridden up!
This is with a Rock Shox Tora RS (with Lockout) I believe they are 100mm travel forks aluminum alloy (may be magnesium, not 100% sure) 100% unmodified (I ground the axle to fit the fork) and using nothing more than a single of Jason from ebikekit's torque arms.
Motor was 9C FH205 in 26" rim -after 100mi of breakin riding and re-adjustment
Suspension was set for max travel/give
Ride up required some tactical pedaling to maintain traction, and honestly was more like bunnyhopping 100s of curbs in a row - I guess this is how mountain bikers traverse rocks, I've seen videos but this was my first real attempt at anything resembling rockhopping - until then I had stuck with just crazy offroad trails. It wasn't super fast going up (adding a rear hub would have helped that considerably).
Coming down.... that was fun... About 4x as fast as going up, have no idea how quick but the suspension ate up the steps like they werent even there... actually it felt like a canter for anyone who rides hoarses, only way I know to describe it.
I did wear a helmet for this but didn't get any video... I only did the run once for a test (figured if somthing broke, like me... I didn't want that idiocy on video), police showed up before I could do a second run and I wasn't about to push my luck that night.
I ride the same bike now with 100s more miles on it and im still running through the woods, hopping (more like running over at a good clip) curbs, etc.
No fork fatigue or breakage (yet).
-Mike
PS: I will at some point... do the run again on video, I may have to do it at night though to avoid trouble... would be even better if I could get a cop to "dare" me, since they are all interested in the eBike and want to try it... I could play it off as if I was demonstrating how useful it could be to a bike officer? Actually... that might work. = )_
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
