justin_le wrote:Affliction wrote:I think it's great you are failure testing all these forks. One question tho, how are you going to account for the effect that regen braking has on the dropouts?
Hey Ben, in this set of experiments we won't be accounting for that. I am very explicitly testing only the failure strength of the dropouts (and torque arms) when stressed to the limit in a single direction. The strength I am sure would be identical in the reverse direction. But the situation of regen in an ebike where you are repeatedly torquing the axle one direction and then the other direction, causing it to wiggle back and forth, loosening the nuts, impacting the torque plate. etc. etc. is a totally different set of tests, and may be subject to another thread here in the future.
ZapPat wrote:I wonder where you found that 10X dropout failure rate when using ebrakes, Ben? This figure seems very high unless you are talking about people using no torque arms at all, and/or not checking their axle nut tightness after installation.
I have been using very intense ebrakes on one bike for a couple months now and have had absolutely no issues with the dropouts, even with the front aluminum alloy suspension fork (but I don't go down 16" steps like dogman!). Mind you I use dual torque arms on both front and back motors - the simple ones come free on 9C hubs now anyways (two per hub), so why would anyone not use them?
One important thing I've found with aluminum dropouts is that there is an initial settling in period after installation, and so it's very important to check the axle nuts during the first few rides. I had to tighten mine up a few times, each time less and less, and now they stay nice and tight even when torque-abused back and forth. Steel dropouts tend to do this a bit too, but much less it seems.
Affliction wrote:Justin, I had this idea in the past but I never got around to making a stamping die.
The flat surface where the axle rests against the dropout opposite the nut is always smooth on hub motors.
I've frequently seen on regular bike hubs where the mating surface on the inside of the dropout has "teeth" on the hub to bite into the frame for retention. <snip>
Please stamp a few axles this way and test the improvement with properly torqued nuts.
Affliction wrote:Those are awesome forks!
Kinda a shame you're gonna wreck em all
justin_le wrote:
Anyways this means that we can do a set of super controlled experiments quantifying the exact effect that different torque arm designs, axle grooves, nut tightnesses etc. have on the spinout resistance of a motor axle, at least as it applies to steel dropouts.
Zoot Katz wrote:Affliction wrote:Those are awesome forks!
It's a great score for providing some kind of bench mark.
Being yellow, I was wondering if they weren't all lemons.
justin_le wrote:I'm going to see what we can setup to generate a full spinout profile for each experiment, so we can see the torque on the 'Y' axles plotted against the axle rotation angle. This will be a lot more informative, comparing for instance how steel gives while alloy cracks, and will eliminate some subjectivity as well, but it'll take some time to figure out the best way to set things up.
dequinox wrote:justin_le wrote:I'm going to see what we can setup to generate a full spinout profile for each experiment, so we can see the torque on the 'Y' axles plotted against the axle rotation angle. This will be a lot more informative, comparing for instance how steel gives while alloy cracks, and will eliminate some subjectivity as well, but it'll take some time to figure out the best way to set things up.
Justin, quick question:
When you were testing the spin out torque on the dropouts with the torque-arm restraint, which was it that gave way and rounded out the most... the axle or the torque arm?
It seems to me that if the torque arm was the part that "ate it" then some improvements could be made by adding a simple tempering process to the manufacture of the arms. If we could get a manufacturer to laser/water cut out the torque arms from 1080 (or perhaps a T1 or 440c stainless) steel, and then heat treat them for a Rockwell hardness of about 35-40... it would be much more resistant to "round-out" than your run-of-the-mill 1020 1/8" plate. Hopefully that hardness would also afford some "toughness" so that the torque arms wouldn't just crack out.
justin_le wrote:It was the torque arms that suffered the most damage for sure. The axles are definitely harder than the stainless.
Justin
Affliction wrote:justin_le wrote:It was the torque arms that suffered the most damage for sure. The axles are definitely harder than the stainless.
Justin
The axle's are harder than stainless? I cut threads in these all the time and it's like cutting butter with my tap and die kit.
You can't drill stainless unless you have special drill bits and usually the bit is ruined once you're done.
You sure your torque arms are true stainless steel?
Affliction wrote:The axle's are harder than stainless? I cut threads in these all the time and it's like cutting butter with my tap and die kit.
justin_le wrote:For sure, we'll get to know for sure early next week. ... It might be that the hardened torque plates just cut through the axles at only a little more torque than the axles were cutting through the softer plates, but we'll see.
live4physics wrote:The most commonly used alloy of stainless steel is 304.
It has a tensile strength of of 73,000ksi and a yeild strength of 31,000ksi
GaryKard wrote:What I would want to know is if dual torque arms offer twice the resistance to spinout or do they give more or less protection than that. Not two arms with one reversed for regen but two mounted the same direction.
dequinox wrote:The reason you have a difficult time cutting stainless is its tendency to work-harden. A drill bit trying to push through stainless steel produces a lot of pressure, and like when you bang a welding rod flat with a hammer at room temperature, the surface of the stainless becomes harder and more resistant to cutting. Only stainless has a much much higher tendency to react this way to machining than mild steel or even the higher carbon alloys. You shouldn't be ruining drill bits if you use a proper cutting fluid, feed rate, and speed with a decent drill press. Even with a regular bench top you should be able to get a few holes drilled before the bit goes dull and you have to sharpen it again.
You might try using your tap and die on a SS bolt the same size as the axle sometime...there may (and I say may because I haven't done this myself) be a noticeable difference in the machine-ability. Something like a 1080 steel might be soft if it isn't heat treated...but try machining it after a good temper is put into it. The higher carbon stuff has higher tensile and yield strengths, but that doesn't necessarily vary directly with its machining characteristics.
Affliction wrote:Ever try and drill through a bearing race? It's near impossible even with Tungsten carbide bits. Yes I know all about cutting oil and how not to ruin a drill bit. On hardened metals I use the old "smoke wrench" to make holes. Then I use a die grinder to make the final shape.
Running a die on hardened steel is a futile effort, you just end up wrecking your tool.
I cut threads all the time and I was just mentioning how soft the axle threads are by the ease of cutting a different pitch for repair.
Hub motor axles appear to be very soft metal.
Users browsing this forum: No registered users and 13 guests
