NRG wrote:Jeremy I wonder if you could help.
I've been messing about with the parameters on an E-Crazyman 6-fet 116 based controller that's driving an SWXB motor.
I understand the current limit control is crude in operation, however, I'm finding the rated current limit I set in Parameter Designer is about 5amps out IE: if I set a 20amp limit the peak draw measured by my Watts Up is 25amp. I suspected the shunt may have some excess solder and indeed it did on one end, removing as much as I could trimmed about an amp of the 'overshoot'...so I'm wondering how accurate current control is with theses controllers?
Also on another note I've set the phase current at 2.3~2.5x the rated current but I'm not sure if this is 'safe' I've noticed the controller gets quite hot, much hotter than before I started messin' about with the settings...any recommendations for this setting?
Many thanks.
Jeremy Harris wrote:
My experience is that the current limiting accuracy (on the main, software set, current limit) isn't great. +/- 3 to 5 amps is about as good as they get. The main issue seems to be variation in resistance of the whole shunt current path, including how much solder there is on the board 0V trace. I don't really think the current limit needs to be much better than this though, as it's only intended to be a rough setting - I doubt most people would be able to tell the difference between 20A and 25A unless they were looking for it.
Setting the phase current for 2.5 times the current limit is OK, but if you are trying to pull 25A from this controller in standard form then it will get warm unless you change the FETs. As standard, they come with either 60NF06 FETs (16 mohm Rdson) or sometimes 75NF75 FETs (13 mohm Rdson). These are quite lossy devices, for example, the IRFB3077 FETs that I'm running in one of these have an Rdson of typically 2.8 mohm. This makes a big difference to how hot they get. For example, 25A through a 60NF06 FET will create around 10 watts of heat (per FET) whereas 25A through an IRFB3077 FET will create about 1.75 watts of heat. The IRFB3077 FETs are good for around 65 to 70V working voltage (they are rated at 75V max) and are a good choice for this controller. Their max current rating is 210A for the silicon, but restricted to 120A by the package. In practice I'd have no qualms at running these FETs at 50A or so in a 6 FET controller, maybe more if the use was such that the controller wasn't being held at high current for long periods of time. A 60V pack with a 50A current limit on one of these controllers fitted with these FETs would be OK for around 3kW peak power, pretty impressive for such a small unit. Change the capacitors to 100V ones (they are usually 63V) and change the FETs for IRFB4110s (100V, about 3.7 mohm Rdson) and you could probably see up to 5kW or so.
Jeremy
NRG wrote:Hi Jeremy, many thanks again for the help. I've upgraded the controller with Panasonic NHG and IRFB3077 FETs, the FETs seem to have made a difference to the temperature as the controller is now just warm to the touch.
Another question if I may: The LVC setting in PD has gaps in it IE: the voltage selection jumps from 32.5v to 40.5v with nothing in between. I'm running 12x Turnigy cells for 44.4v and would like LVC set around 36~38.5v Is there anyway of achieving this in s/w or does the controller need modding?
I think Ed Lyen's version of the software has a complete selection, but you have to buy one of his controllers to get it. Easiest solution is the selectable voltage cutoff on the Cycle Analyst. The best solution is Gary Goodrum's LVC boards, which monitor each individual cell. Between the CA for the total pack and an LVC board on the balance taps, you are more than covered.NRG wrote:Another question if I may: The LVC setting in PD has gaps in it IE: the voltage selection jumps from 32.5v to 40.5v with nothing in between. I'm running 12x Turnigy cells for 44.4v and would like LVC set around 36~38.5v Is there anyway of achieving this in s/w or does the controller need modding?
gensem wrote:I have a quick questiin about 3 way switch/throttle %
How does this setting control the max speed?
I dont think its advancing/retarding the timing because that wouldnt work with sensorless hubs. Cant be reducing amps either.
Btw should I expect more heat from the hub running at lets say 60 70%?
Thanks
Thanks
Arlo1 wrote:IM back at it again... Stupid windows 7 is stoping my this time so now when I do it the way you say for a 64 bit system I get the error code
"c:\\Windows|SysWOW64\MSCOMCTL.OCX" was loaded but the DllRegisteredServer failed with error code 0x8002801c"
gensem wrote:Arlo1 wrote:IM back at it again... Stupid windows 7 is stoping my this time so now when I do it the way you say for a 64 bit system I get the error code
Try to unregister and register the dll again.
regsvr32 -u c:\Window\SysWOW64\MSCOMCTL.OCX (to unregister)
regsvr32 c:\Window\SysWOW64\MSCOMCTL.OCX (to register)
btw check if the file is in that folder.
Arlo1 wrote:IM running or should I say blowing up 24 fet controllers and the xpd doesn't currently support them!
Users browsing this forum: skeetab5780, tmho and 5 guests
