Arlo1 wrote:IM back at it again... Stupid windows 7 is stoping my this time so now when I do it the way you say for a 64 bit system I get the error code
"c:\\Windows|SysWOW64\MSCOMCTL.OCX" was loaded but the DllRegisteredServer failed with error code 0x8002801c"
gensem wrote:Arlo1 wrote:IM back at it again... Stupid windows 7 is stoping my this time so now when I do it the way you say for a 64 bit system I get the error code
Try to unregister and register the dll again.
regsvr32 -u c:\Window\SysWOW64\MSCOMCTL.OCX (to unregister)
regsvr32 c:\Window\SysWOW64\MSCOMCTL.OCX (to register)
btw check if the file is in that folder.
Arlo1 wrote:IM running or should I say blowing up 24 fet controllers and the xpd doesn't currently support them!
Bubba wrote:I've got a question. I've searched for hours looking for a straight answer with no luck....
Which Switch setting do you use on the Lyen 12FET controller when using a Hall Effect throttle? I see Button and Switch options only.
Also, do the three speed settings have any effect?
Thanks in advance!
Arlo1 wrote:Bubba wrote:I've got a question. I've searched for hours looking for a straight answer with no luck....
Thanks in advance!
Haha the switch setting is to choose wether your three speed switch is a switch or a button. And yes the speed settings work eg. 50% is 50% of everything power and top speed!
Bubba wrote:[
But I'm not using either a switch nor a button. I'm using a hall effect throttle.
kevo wrote:Three speed switch is nice!
Users browsing this forum: pschmatz, raveruk1, steveo, Trilska and 12 guests
