gwhy!
I have a 806 and works perfectly default set to 120 degree timing but I have just received a new controller , its a 206 and I have a problem with the timing. Is there a hardware setting to set the timing as well as using the software on the 206. I have software set the timing to 120 degrees but the motor will not run correctly it ran better before i re-programmed ( maybe it was default set for auto timing which I will re-try ) but it still did not run perfect anybody got any ideas? if there is a hardware setting would this have to be matched to what the software is set to...
