I like the design of the motor for pedals.
Jeremy Harris wrote:...I'd thought of a variation on this basic idea, using lengths of toothed belt rather than steel cables. These could be wrapped around pulleys, fitted with internal one-way clutches driving a common shaft, to give semi-continuous rotary drive.
Jeremy
John in CR wrote:Do all of these approaches, including the one in Olaf's initial post, all share the one significant flaw with retro-direct? That is a bike that cannot roll backward at all. I think they do.
TylerDurden wrote:John in CR wrote:Do all of these approaches, including the one in Olaf's initial post, all share the one significant flaw with retro-direct? That is a bike that cannot roll backward at all. I think they do.
If they are driving a rear hub with freewheel?
olaf-lampe wrote:Yes John you are right. I tried to turn the shaft of the boxer backwards and it didn't work. You'd need to add a clutch somewhere or simply lift the rear wheel![]()
Thanks Jeremy for joining in with these additional informations. The looong cranks from the bike are not helping to reduce the hull size but it's worth a try in a normal frame.![]()
Maybe we should start a craziest pedal propulsion contest![]()
My favoured so far is the tandem rowing bike, this is soo sick.
-Olaf
bzhwindtalker wrote:hum I thougth it used a stepper but I was wrong
http://poisson.jp.free.fr/zebulon2/index1.html
John in CR wrote:A a single rowing bike with a fairing should be able to break the 81mph HPV world record, since you could transfer so much more power to the wheels than pedal alone via legs, back, and arm muscles, just like rowing. Once you make it a tandem, it should be able to slaughter the record by a wide margin, since you gain almost no additional wind resistance but double the power and can make the power transfer continuous instead of discontinuous. I'll leave coming up with that kind of thing to you cyclist guys. In the meantime, I just want to break the HPV record using an electric motor, which should be a matter of simplicity. I also have a both a current bike build as well as the next one in line where I see a linear stroke as great benefit in terms of space and comfort.
An electro magnetic toothed clutch/brake as the clutch for this mechanism to allow reverse might be ideal. Then unpowered would be engaged, and in those rare events you need to roll backward it uses a bit of juice. I can foresee instances, like stopped or parked on an uphill, where the inability to roll backward would be a plus.
John
Jeremy Harris wrote:John in CR wrote:A a single rowing bike with a fairing should be able to break the 81mph HPV world record, since you could transfer so much more power to the wheels than pedal alone via legs, back, and arm muscles, just like rowing. Once you make it a tandem, it should be able to slaughter the record by a wide margin, since you gain almost no additional wind resistance but double the power and can make the power transfer continuous instead of discontinuous. I'll leave coming up with that kind of thing to you cyclist guys. In the meantime, I just want to break the HPV record using an electric motor, which should be a matter of simplicity. I also have a both a current bike build as well as the next one in line where I see a linear stroke as great benefit in terms of space and comfort.
John
I doubt that a rowing bike would be any faster, as the human body power limit at present is aerobic. Using more muscles groups does increase the initial power available, but the body will quickly go into oxygen deficit because the lungs won't keep up with the muscle oxygen requirement. It's a bit like the analogue of a big motor and controller with a small battery. At first the motor will deliver loads more power, but the battery will soon give out. Our legs alone at full power can overcome the ability of our lungs to provide adequate levels of oxygenated blood, probably because we evolved to be pretty good at running...
John in CR wrote:That makes sense for the how far you can get in an hour HPV record, but I was thinking of the absolute speed record, which is a sprint. I wonder how long it takes before the aerobic limit is dominant.
Users browsing this forum: Bing [Bot], Lory and 8 guests
