by dnmun » Fri Jul 30, 2010 12:58 am
you post a picture by going below the section where you enter text, select (upload attachment) and then search out your picture by browsing on your disk
the B- goes to the negative terminal of the battery and the P- is the lead to the negative wire on the controller.
you charge the pack by connecting the negative terminal of the charger at C- and the positive of the charger directly on the positive of the battery.
the little red wire on the controller is for your circuit current and you need to place a switch on that line or the controller circuit current will discharge your pack while sitting. the large red wire of the controller goes directly to the pack positive.
