Jeremy Harris wrote:......There's a reset button on the controller that if pushed at power on resets the gauge to 'full'......
Jeremy
Cycle Analyst works the same way, I copy from http://ebike.ca/drainbrain/CycleAnalyst ... Vers22.pdf
1.2 Resetting
After you have recharged the battery pack, you should reset the trip
statistics (Ah, Distance, and Time) to clear them all to zero. This is
done by pressing and holding the right button for 1 second, until the
message “Reset†shows up across the display.
My cell phone has no reset button for the battery fuel gauge. My laptop has no reset button for the battery fuel gauge. My Bionx Electric Bicycle has no reset button for the battery fuel gauge. I would like for my Electric Bicycle Project # 2 to have no reset button for the battery fuel gauge.
See picture of The BionX Console
Still unfinished Electric Bicycle Project # 2 will use a GBP Battery Co / 48V 20Ah Li-ion battery.
Will this work with my battery? I don't care if it is not real accurate.
Curtis Model 906 Battery Discharge Indicator
http://www.curtisinstruments.com/index. ... y&catID=15
Data Sheet
Manual
D E S C R I P T I O N
Model 906 is an inexpensive, one piece, easy to install
battery fuel gauge. It is completely solid state and provides
a reliable, accurate, and easy to read display of battery
state-of-charge. Model 906 is available in six panel mount
packages and a printed circuit board mounted module for
custom dash panel applications.
A P P L I C A T I O N
This battery fuel gauge features Curtis patented technology
and is ideal for golf cars, commercial cleaning equipment,
mobility aids, electric bicycles, electric marine motors,
medical devices, and similar equipment.
• Three possible reset methods:
1. Open Circuit Reset (OCR): Upon reconnection of a
battery the gauge will reset if it measures 2.09 volts/
cell or higher (example “B†profile) (for units with
memory option).
2. High Voltage Reset (HVR): Gauge must measure
>2.35 volts per cell for 6 continuous minutes during
charging (example “B†profile).
3. Charge Tracking Reset (CTR): Display tracks charge
level during opportunity charging (requires gauge to
be connected to battery when charging).
