chvidgov.bc.ca
Hello. I'm running the veloamp ebike stereo amplifier from ebikes.ca - great sound, and I'm having a problem with the reception of motor phase hum on the MP3 input line. When I have my player connected, and playing, it works fine. However, if I shut the mp3 player off, I suddenly get fairly loud phase noise playing through my speakers, as though it were picking up interference from the controller. If I remove the jack to the player and hold the end of the jack in my finger it makes the noise even louder, as though my body were amplifying the signal too. So, when my player is out of juice, and I take it off the jack, my bike is suddenly a lot louder, with motor noise coming out of the speakers. How can I isolate the jack? If I pull the jack right out of the amp itself on the other end of the line at the amp, the noise doesn't happen. It is as though the input line in is acting as a kind of antenna when the player is not operating. It is still present but not so loud when I leave the line jacked into the player, with the player off. It doesn't seem to be picking it up "through the air", as I can run the whole system with no problem, on a different battery, but in the same physical position - no interference. So, the phase signal is somehow getting into the line physically? from the controller or something.
What do the electronics experts say?
