mortain wrote:yes, ok...but what' s the trouble when you increase the capacitance of the circuit?, because I see few ultra capacitors which have very very low ESR ( bcap1200p270T05=0,56 mohm!!!) much better than audio car caps . I remember the threaads p 32 of this forum ( thanks to cesare250495 and Jeremy Harris) and the texaspyro comments... If amperage is pregnant, is it possible welding with a very low voltage
zakipu wrote:I have only one question for texaspyro: what are you using for vent sensing?
mortain wrote:Ok, thanks everybody. one moment, i have hoped that we could weld under the 15 volts
FastDemise wrote:Just curious how much capacitance do I really need? I am getting (.8F) 8x of these http://www.digikey.com/product-search/e ... 104U016X5C getting a 1000v 200a SCR.
texaspyro wrote:FastDemise wrote:Just curious how much capacitance do I really need? I am getting (.8F) 8x of these http://www.digikey.com/product-search/e ... 104U016X5C getting a 1000v 200a SCR.
Why pay $400+ for those caps when a Rockford/Monster Cable/Scosche cap can be had for $50 or so and will probably work better?
To do serious welds you will need around 3F. And that SCR will be vaporized.
FastDemise wrote:So my SCR is rated at 1600v 200a = 320kW
Using the 320kW but at 16v that's 20,000A it should be able to handle?? With the math showing the low resistance of the caps able to push 12,000A. Am I wrong in thinking the SCR I have will work on paper or am I just using ohms law all wrong?
malcav wrote:I'll start with I am sorry i did not read the whole thread so my Q may have been answered. But what is the best type of cap to use? Like aluminum or ceramic?
texaspyro wrote:Nice rounded tips work best. The diameter of the point is best determined by trial and error and sparky smoke.
texaspyro wrote:Finer/sharper points are not necessarily better points. They can give tiny weld spots and current densities that are too high and blow out the weld point. And flat points are a no-no... you will never get the electrodes square to the material, yielding the same problem as sharp points. Nice rounded tips work best. The diameter of the point is best determined by trial and error and sparky smoke.
Users browsing this forum: Bing [Bot], bobc, stevetooke and 10 guests
