torque arm picture thread
Re: torque arm picture thread
Postby Arlo1 » Fri Aug 19, 2011 6:15 am
Spacey wrote:
Arlo1 wrote:I belive in a pinch bolt for hi power apps with regen!
Love your pinch bolt idea of welding the nut onto the frame, I take it the weld holds up just fine?
Also those holes in your motor, I might do the same to my HS3540 not for cooling but for the UK rainy weather in the winter...and the summer grrrr
I live on vancouver island in a rain forest! I ride in the rain all the time the heat in you motor keeps it dry inside! Yeh I get some pretty good torque on the pinch bolts and if you can't weld a nut then just get a peice of steal with a hole in it to weld to the frame.
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby dogman » Fri Aug 19, 2011 6:34 am
I would think water in the motor would be pretty harmless compared to the dry sugar sand I have rooster tailing from my rear tire.
I see your point John, about the two bolt setup I use. That's why I have the second nut on there, locknuting both bolts. Coming up on a year's use now, and never had it work loose. I torque it pretty good, using grade 8 bolts that can take it, then romp down the locknut. My idea is only going to work well with a bike like the mongoose, that has a huge flat steel plate for a dropout.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Arlo1 » Fri Aug 19, 2011 9:02 am
dogman wrote: My idea is only going to work well with a bike like the mongoose, that has a huge flat steel plate for a dropout.
Thats why I welded 1/4 inch steal to the drop outs!
Arlo1
Postby John in CR » Fri Aug 19, 2011 4:20 pm
+1 on the 1/4 plate for dropouts. That's all I use and then since I like at least double that at the axle, I use much smaller pieces to thicken at the dropouts.
John in CR
Very Informative!
Postby TonyReynolds » Fri Aug 19, 2011 11:31 pm
Thanks!
Third Build: 2012 Marin Muirwoods 4130 Cromoly, 7 speed 11/32 with 500/1000W MAC geared rear motor, 48V System, 52V, 11.5Ah 16s5p A123 lifepo4 triangle battery, DP CA; 20-30+ MPH... GRIN! Build Thread: http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=33819
cell_man... Supplier of A123 Cells and MAC Hub Motors: http://www.emissions-free.com/id47.html
TonyReynolds
Postby auraslip » Sat Aug 20, 2011 6:35 pm
Ok I've re-thought this torque arm situation. I want it to be simple. Meaning I can do it with hardware store parts. It also needs to be relatively easy to remove for tire changes (not that it's really an issue with the right precautions)
The main problem for me was derailleur clearance. It dawned on my that if I could spin the axle 90" then it wouldn't be an issue, so I filed my drop outs so that the flats of the axle would be horizontal. And now I have lots of room!
This is about as good as I can come up with. I haven't worked out the actual hardware, but I'm thinking 1/8" width by 1" wide L bracket for the top, and 1/4" steel plating on the bottom. Since they'll be pressed right against the original drop outs and the chain stay protrudes out a bit, the L bracket will have to have the bottom leg removed and both torque arms will have to be trimmed to clear the chain stays.
It will be secured to the drop out with bolts and to the chainstay with a U-bolts. I'll apply the pinch bolts first, and then the U-bolt, and then FINALLY drill into the dropouts. This way the chainstay will see most of the torque, rather than the weaker aluminum drop outs.
John says the big problem with this design is the complete reliance on bolts to produce the pinching force, and I agree. However, it would be easy to modify this quick drawing by using a larger L bracket to incorporate 4 bolts rather than just 2. This would spread the clamping force out along the axle. The devil is in the details, so if any of you have any suggestions I'd love to hear them. I believe this design is solid because it's based on KISS principles. It should work for most bikes, is simple to remove, and is easy to do correctly; All you need to make it is the hardware, a hack saw, and a drill. A tap would be superior than just using nuts, but is not totally necessary.
auraslip
1.21 GW
1.21 GW
Postby John in CR » Sun Aug 21, 2011 12:51 pm
I wouldn't call bolts a big problem at all. I just know how I am about preventive maintenance and pre-flight safety checklists, so reliance on bolts is a bad idea for my own bikes.
John in CR
Postby Kingfish » Sat Sep 17, 2011 11:07 pm
Kingfish wrote:Image
Still working for me after 3-1/2 months :twisted:
~KF
New and improved!
I thought that I would update this information. The ghetto front torque arm was replaced after 7 flawless months in July with my custom designed and professionally machined assembly. Mounted as a pair, they survived 2500 miles On the Road to California and back without any issues. The 2WD eBike had regen on the front hub only. I was grateful that this was one of the least problematic items on my trip and remained tight the whole time :)
Chief features are:
  • new EBike-Kit hub motor with disc brake option
  • enabled the disc brake, and
  • designed a 2-link and clamp assembly.
The keyed torque arm is crafted from 1/4" thick stainless steel, whereas the link and clamp are from aluminum. Stainless steel fasteners were used to attach the pieces, and Blue Loctite was used all threads - including the M14 nut.
Cheers, KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9634 miles-to-date, 4144 as 2WD.
Kingfish
1.21 GW
1.21 GW
Postby auraslip » Sun Sep 18, 2011 12:26 am
Nice KF - I'd like to know more about that. Where you got it made, etc etc.
I have that same fork BTW. Right down to the gold speckled "fishing lure" paint job.
Do you have anymore pics of your bike ? I wanna see a cross country riding 2 wheel driving bike!
auraslip
1.21 GW
1.21 GW
Postby Kingfish » Sun Sep 18, 2011 2:10 am
auraslip wrote:Nice KF - I'd like to know more about that. Where you got it made, etc etc.
"fishing lure" paint job: hehe - yeah it reminds me of that too :lol:
The trip is in my sig :) The last 3 pages of the thread provide a good concise brief of each day and there are plenty of pics in the backfilled stories. Page 27 has several pics as well.
The design is mine; I used AutoCAD to draw it up, and I had it made locally. There are essentially four parts: linkage (arm and link) and clamp (2 halves). It's a pretty straight up design that works around the disc brake mounting. My machinist prefers anonymity. It has crossed my mind to do a production run. The big question is matching the diameter of the fork.
If there is enough interest and commitment I can make these available to ES folks.
Best, KF
Kingfish
1.21 GW
1.21 GW
Postby Diamondback » Sun Sep 18, 2011 2:33 am
id be interested in a pair of these if you do decide to make a production run.
Jason.
Ignorance can be solved, stupid is forever
Diamondback
Postby Kingfish » Sun Sep 18, 2011 3:03 am
Diamondback wrote:id be interested in a pair of these if you do decide to make a production run.
Jason.
Cool! :) I need to collect a bit of data to ensure a proper fit. Here’s what I would like to see:
  • Take a close-up pic of the fork where the axle passes through – with the M14 nut removed, and/or provide the year make and model of the fork.
  • Also it would be helpful to measure the fork diameter where the clamp will go: Take the measurement from the axle equal to the radius of the hub motor – just above where the disc brake mounts as displayed in the image of mine. Suspension Forks are often egg-shaped or oval instead of perfectly round, therefore we need to take this diameter measurement in two directions: Front to back, and from the inside to outside. I use digital micrometers and the preferred units are in millimeters, although I can convert inches to mm easy enough. Make sense? :)
If we get enough people to commit and if the fork diameters are close enough then a production run is feasible at a reasonable cost.
Best, KF
Kingfish
1.21 GW
1.21 GW
Postby Diamondback » Sun Sep 18, 2011 3:41 am
sounds good.
ill have to get some measurements made.
gives me the excuse to go buy a set of digital verniers.
been wanting a set for a few years, now i have a good reason to go buy a set :D
Jason.
Diamondback
Postby jhinshel » Fri Oct 07, 2011 1:26 am
Hi,
I am after a cad (or similar file) for a torque arm. I appreciate that I would have to adapt this, but this would serve as a good starting point for me.
I would be grateful if someone could make one of these available.
justin
jhinshel
Postby John in CR » Fri Oct 07, 2011 7:51 am
jhinshel wrote:Hi,
justin
Justin,
They're so easy, how about you try to come up with an even better design? An ideal torque arm that will fit any bike has been elusive. Ideal includes simple, as little steel as practical (for those who erroneously think ounces matter on even such a critical part of an ebike), but with a broad surface that clamps firmly to the axle.
John in CR
Postby Quajochem » Wed Apr 04, 2012 6:55 pm
I have 2 good thicker torque arms now! and they are VERY well secured!! Because this happened to my first arm in my first 200m with my mac: :oops:
I grinded the axle to an exact fit on one side now:
I also tried to dissipate the forces evenly on the fork as to stress it as less as possible.
On one side I made use of the eh 'thing/brackets' that normally hold the diskbrake caliper.
I also looked at the direction they want to turn in when you hit the throttle.
O in fact there are 3 torque arms on it.
:D
Quajochem
Postby Timma2500 » Wed May 30, 2012 12:04 pm
I got some ideas from this thread for my torque arms so i thought i'd contribute what i learnt.
10mm thick mild steel made using a grinder, drill, file and M6 tap:
Paul :D
Intense M3 DH, HT3525 / 5kw, 18fet, 20s 10ah nano lipo
Norco Empire 5, 80100 130kv / 5kw, HV160, 12s 12ah lipo
Under Construction
Timma2500
Postby neptronix » Wed May 30, 2012 12:49 pm
These plates tolerated 6kW-8kW of very torquey power for a good amount of time, and pretty strong regen as well ( 700-1250w ).
In the end when i dismantled the magic pie bike and sold it's componentry, after almost 2 years of abuse, i still had to bang on the axle to get the motor out of it's dropouts. I looked at the torque plates and they were still perfect. I couldn't believe it.
I've been preaching this method of making torque plates for mid-high power setups for a long time now. They might not have stood up to a Crystalyte 54xx or cromotor hubzilla, but they were pretty effing strong.
Always overbuild your torque mounting bits. You'll pat yourself on the back later rather than kicking yourself in the ass as you gradually pump more & more power into your motor :)
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby Farfle » Wed May 30, 2012 3:34 pm
here is the axle/dropout setup from the dual pie. Better than clamping dropouts. good for 3.5kw of regen, and 22kw of output power.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby spinningmagnets » Wed Aug 22, 2012 4:59 pm
Cross-posting these two threads so a search will turn up both:
"Found an awesome torque arm" (3 pages)
http://endless-sphere.com/forums/viewtopic.php?f=1&t=11570
Some pics of what happens when you don't use a torque-arm, and the wires in the hub are ripped out at the root..
Last edited by spinningmagnets on Wed Jan 09, 2013 8:26 pm, edited 4 times in total. View post history.
spinningmagnets
Postby RC Extreme Power » Mon Aug 27, 2012 9:45 am
My solution after mistake of not using them.
Sorry I do not know how to post pictures direct into post.
Milton
(144.92 KiB) Downloaded 6 times
RC Extreme Power
Postby John in CR » Mon Aug 27, 2012 10:12 pm
Paul,
I'm sorry I missed this one back when you posted it. That's pure artistry with a grinder and a file resulting in a perfect torque arm in both looks and function.
John
Timma2500 wrote:I got some ideas from this thread for my torque arms so i thought i'd contribute what i learnt.
Paul :D
John in CR
Postby GMUseless » Mon Aug 27, 2012 10:38 pm
John in CR wrote:Paul,
John
Paul :D
Indeed! I hand filed and grinded the arms for my Kona Supreme, mine look terrible, and it was an assload of work. Yours look CNC'd...to have been done by hand is mind blowing.
GMUseless
Postby spinningmagnets » Thu Sep 13, 2012 1:18 pm
spinningmagnets
Postby auraslip » Mon Sep 17, 2012 7:41 pm
Sorry for the crappy picture.
Torque arms were from DOC. Decided they had too much play to be useful.
Chopped them up and tapped them out to make them clamping.
Then Glued to the frame.
Then decided they should be drilled in.
Hard metal. Got really hot drilling it. My bad. This made the glue pop one off.
Oh well. They work fine for 6kw.
Will they work for 10kw?
Loving how easy it is to remove the motor though!
auraslip
1.21 GW
1.21 GW
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: gensem, outbackhack and 9 guests
