Upload Your Circuit Schematics & Requests Here...
Re: Upload Your Circuit Schematics & Requests Here...
Postby The Mighty Volt » Wed Mar 24, 2010 3:06 pm
Hi...the only schematic I would like is for how to tab-weld/arrange A123 cells into a 72v 12Ah pack with wires for charging and discharging. Thanks. :P
The Mighty Volt
Postby amberwolf » Wed Mar 24, 2010 4:26 pm
That's going to have more to do with what space you have to put them in than anything else--you'll need to figure out what shape and size you have to work with, then figure out how the batteries will best layout within that space, before you can figure out how to connect them. :)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby The Mighty Volt » Wed Mar 24, 2010 7:23 pm
amberwolf wrote:That's going to have more to do with what space you have to put them in than anything else--you'll need to figure out what shape and size you have to work with, then figure out how the batteries will best layout within that space, before you can figure out how to connect them. :)
Yes..sorry..I should have included that. :(
I am planning on fitting 100 A123 into an augmented space within the frame of my MTB, the triangular piece where the cross bar, diagonal and upright meet. I dont know whether to go for a "perfect fit" triangle or whether to make up 8 cell packs with balance tabs and charge them with a Turnigy Accucell. Even if I knew that, I still would not be sure of how to connect the packs to come out with the 72v 11 Ah which 100 A123 M1 cells should provide.
I will probably need pictures to better inform people, so I will take care of that tomorrow.
Cheers. :P
The Mighty Volt
Postby amberwolf » Thu Mar 25, 2010 4:01 am
The Mighty Volt wrote:I am planning on fitting 100 A123 into an augmented space within the frame of my MTB, the triangular piece where the cross bar, diagonal and upright meet.
Assuming you mean the front triangle's toptube, downtube, and seattube (the "bike shop" names for the three main tubes of the front triangle), the first thing to determine is if indeed 100 of them *can* fit there.
Each one is 28mm diameter, give or take a bit. Assuming staggered rows for least space wastage, and that they'll be in a "single file" pattern so there is only one "layer" of them, with the ends of the cells pointed left and right of the bike, perpendicular to the bike's length. Then there is the thickness of whatever you use to space them apart a bit so they can't rub on each other and short out. Then the thickness of whatever you use to encase them so they don't rub on the bike frame itself.
FWIW, the overall idea is a common one for triangle-mounted packs of cylindrical cells. It is one possible plan I am considering for my LiPo/LiCo cells, once I get a BMS for them to safely use them without risk of destruction. ;)
Assuming they all fit, then for 3.3V per cell to get 72V you have to put 22 cells in series (72.6V, actually, nominal, though they could be as high as 3.6V+ per cell bringing the pack hot-off-the-charger voltage to at least 79.2V).
Assuming 2.3Ah per cell, then for 11Ah you'd need 5 strings of 22 cells in parallel, which actually comes out to 11.5Ah.
That's a total of 110 cells you'll actually need to fit in that triangle, plus insulation/casing/etc.
As for how to build it pack-wise, it depends on how you intend to charge it. If you are going to use an 8s charger, you're only going to be able to charge a bit more than two thirds of the pack that way, as it will be two 8s sections and one 6s section. So you also need a 6s charger, unless the 8s is a smart charger that can deal with 6s as well.
What I sort of planned to do with my LiPo/LiCo cells was build them into ~12V sections, as if they were SLAs. So they'll actually be about 14.8V sections, wired up in 4S blocks. Conveniently, the Fechter/Goodrum v2.6 BMS was in 4S sections, so each little board could go with a "mini pack", with interconnects to all the others in series, *or* to a separate control board (which I'd have to cut off of it's own little 4S board, since it's not normally separate). That way I don't have a whole bunch of little balancing cables running off to a main BMS board--I just have the series interconnect wires, which should be fewer in number.
I could then use these "12V blocks" to build whatever pack I needed for that testing or operating configuration, since it seems most common to use 12V increments for controller voltages. If I wanted I could parallel several sets series'd together, and then just series *all* of the sets together to charge them, without worrying about disconnecting/connecting the balance wires.
The actual wiring of your pack could be 5 separate series strings of 22 cells, or it could be 22 stacked parallel-wired sets of 5. I think the latter approach is the more recommended one from what I have read around the web, but it has it's disadvantages, too (if one cell dies totally shorted it'll take out everything directly paralled with it--not a likely scenario but a possible one).
[/quote]
You'll also need to get dimensions of the inside of the triangle, so that you can verify they'll fit.
One way to do this is to take a photo of the side view of the triangle from as far away as you can get with your camera and still use it's optical zoom function to fill the screen as fully as possible with the triangle. That way you can use that as a reference in the computer to begin drawing circles in it to determine if it will all fit.
Alternately, just lay the bike frame on it's side (this is easiest if it has no cranks or handlebars or seat on it, but usually just taking off the pedal from one side and taking the front wheel out will let it lay flat enough to do this). Then start placing actual cells in there, sitting on their ends on the floor, to see if they will indeed all fit in that space and leave you room for casing around them and such.
amberwolf
Postby The Mighty Volt » Thu Mar 25, 2010 9:02 am
Hi amberwolf. Thanks for that informative post!
I already conducted a very basic experiment to the effect that I took a sheet of ply, held it to one side of the triangle, and went around the far side with my pencil and drew the outline from the interior of the triangle.
Then I measured each battery and figured out how much I needed to extend the frame by.
Finally, I began to arrange the batteries on the pencil outline and found that, from what I can gather, I can definitely fit 100 on the triangle, absolutely.
Of course, once glue, insulation, wires etc begin to play their part....it may drop a bit
72v is the predominating feature, as the controller is 72v controller.
The Capacity only becomes pertinent when you consider {a} the basic necessity of range itself and {b} the more technical necessity of providing the requisite 50A to the controller.
I think 10Ah should secure both of those requirements...albeit in a limited fashion.
Stand by for pics...and thanks for your time. :!:
The Mighty Volt
Postby kwheels » Mon Mar 29, 2010 4:28 pm
This is probably really simple, really bad, and has been uploaded before....but
Heres my schematics to run the Kelly KDS48200 at 48V with SLA's
edit: its based off of the schematics that kelly provided, but with a circuit breaker instead of a contactor....its essentially a simplified version of theirs, with no reverse circuit for a fixed magnet motor
48V GoPed ESR750EX, 12v12ah SLA's, Hayes Hydraulic Brakes, Kelly KDS48200 Controller
kwheels
Postby spinningmagnets » Mon Aug 09, 2010 12:47 am
Circuit request...I'd like a schematic for a pigtail (to be connected permanently on the controller) in between the controller and battery, so when someone tries to plug the battery in backwards they don't fry the controller.
Red and black, of course, and polarized Anderson plugs, but I can visualize someone getting a new battery pack, and attaching their own plugs (in an attempted upgrade), but they end up attached backwards...
spinningmagnets
Postby amberwolf » Mon Aug 09, 2010 1:31 am
Well, short of a diode in series with the pack, which will have to be capable of handling the entire battery current supplied to the controller, the only other way is a diode reverse polarity *across* the terminals, and a fuse in series with one or both of them.
That way if it's plugged in backwards, the diode will bring the voltage across the controller inputs down to the diode drop (around a volt at high currents like this), and the fuse will blow from the current (which will be whatever the max the battery is capable of putting out when shorted like this).
Schematic to come when I get my trackball cord working long enough (yet more of my bad luck run, I guess).
EDIT: I guess if i hold the cord right it works, so:
battery protection.PNG (4.03 KiB) Viewed 2078 times
amberwolf
Postby fechter » Mon Aug 09, 2010 11:26 am
There is another way. In this configuration, the FETs are being used as "ideal" diodes.
If the battery is connected properly, the FET will turn on. In reverse, the FETs stay off and nothing blows up.
The problem here is the FETs have to handle the full load current, so you may need many in parallel to keep the heat down. Using a very low on resistance FET helps too. I usually estimate about 20 amps per IRFB4110 with no heat sink. With a heat sink, they can handle a lot more. But we don't want it to get hot. You could use about any N channel Mosfet, but do the math on the heat dissipation.
The gate drive resistors will drain about 1uA per volt of pack voltage, so not a big deal. As shown, a minimum of 24v is needed on the pack. For lower voltages, R1 would need to be reduced.
Reverse Polarity Protector.jpg (31.46 KiB) Viewed 2437 times
fechter
Postby spinningmagnets » Tue Aug 10, 2010 1:00 pm
Thanks AW and Fechter! I very much appreciate your help. Perhaps I will make these...and call them the "positive E-Fecht" (The name "Amber Wolf" is already being used for my line of long-bikes)
Amberwolf, Is there a re-settable breaker that could be used in place of a fuse? similar to the push-button on a GFCI? Though I believe shorting the battery can damage it, My main concern is a friend buying a set-up from me, and after modifying the connectors (backwards by accident) he ends up frying the controller.
spinningmagnets
Postby amberwolf » Wed Aug 11, 2010 12:26 am
You could use any breaker, but in my experieinces so far breakers take long enough to pop vs a fuse that you might blow up a BMS on some of these packs before the breaker pops. I guess if you size the breaker right it shouldn't be a problem, and there probably are faster-blow breakers, but the average cheap ones sure take a heck of a long time (sometimes several seconds of "normal" overcurrents; up to a second on a dead short).
As long as the diode is sized right to handle the current flowing thru it, and heatsinked, it'll handle the current flow as long as is needed and prevent the controller from being damaged. But it will be large and with a heatsink will add bulk to your setups. If it only needs to handle an instant of overcurrent, it can be a lot smaller and maybe not need any heatsink.
Fechter's is a better approach for a pass-thru protection than a diode in series would be. Mine is just copied from what I have read of others using here on ES, and is a brute-force protection. Also, with mine, if the diode fails before the fuse blows, it won't help the controller any. Two or more in parallel would mitigate that some, but it's still possible that a really high-current capable battery pack could source enough instantaneious current at a short to fry the diode(s) before a breaker pops (hopefully not before a fuse does, if the fuse is sized right).
amberwolf
Postby bandaro » Tue Aug 17, 2010 7:21 am
ok, i have more of a question than a request, if i was to use 12 lfp4 cells, hooked in series, could i have them permanently in series as well as having them in 4 sets of 3s for the charging? so basically could i balance charge as 4 sets of 3s while the pack is still connected (but no load) as a 12s pack? or will this destroy charger/cells/void balancing effect?
bandaro
Postby fechter » Tue Aug 17, 2010 9:01 am
bandaro wrote:ok, i have more of a question than a request, if i was to use 12 lfp4 cells, hooked in series, could i have them permanently in series as well as having them in 4 sets of 3s for the charging? so basically could i balance charge as 4 sets of 3s while the pack is still connected (but no load) as a 12s pack? or will this destroy charger/cells/void balancing effect?
You can do this as long as the charger outputs are isolated. If the negative charger output is connected directly to the ground pin on the AC plug, it is not isolated and will short the pack when you plug in more than one (smoke, fire, etc.)
fechter
Postby bandaro » Tue Aug 17, 2010 7:24 pm
hmmm, ok, sounds promising then, but i cant find anywhere that says either way for the charger i have, could i hook a multi meter up to it and find out that way? but use the neg wire as its dc input?
this is the charger: http://www.hobbycity.com/hobbycity/stor ... duct=11170
bandaro
Postby amberwolf » Tue Aug 17, 2010 8:47 pm
There are a few posts around describing how to use a meter to test for isolation in power supplies, but you may have to use Google to do a site search rather than the forum search.
amberwolf
Postby fechter » Wed Sep 01, 2010 11:45 pm
bandaro wrote:hmmm, ok, sounds promising then, but i cant find anywhere that says either way for the charger i have, could i hook a multi meter up to it and find out that way? but use the neg wire as its dc input?
Sorry for the delay here.
The charger shown uses a power supply (not included). The power supply is the part that needs to be isolated. To test, use an ohmmeter from the ground pin on the AC plug of the power supply and measure to both output terminals. If you see a reading that is near zero (usually to the negative side), then the supply is NOT isolated. If it is isolated, the reading will usually be above 10k ohms or so. Most power supplies are isolated, but you just want to be sure.
fechter
Postby bandaro » Sun Sep 12, 2010 2:43 am
thanks fetcher, that exactly what i needed.
So i was hit by a car hence the wait (dw, wasnt on my bike at the time and im feeling fine, just severe concussion), but i just tested the supply, a converted pc one. im assuming the ground is also called the earth (here in australia) and is the middle offset pin on the ps box? i got no connection for the negative wires but around 264 for the 12 volt wires and 32 for the 5v ones so i can charge the bike batts as 4 sets of 3s while still all connected in series right???
sorry for all the questions, i just cant really afford a noob mistake that wrecks my batts, so thanks all for the patience :D
bandaro
Postby fechter » Sun Sep 12, 2010 9:51 pm
Hope you're OK after that crash. Be careful.
Yes, we call the earth ground over here.
I don't think you can run more than one charger off the same supply. You'll need a separate supply for each one. Your measurements look OK, it should be isolated enough.
It is possible the chargers themselves are also isolated. If there is no connection between either of the input wires and the output wires, it could be.
fechter
Postby bandaro » Mon Sep 13, 2010 12:21 am
ok, thanks!
checked the input/output wires, shoved one sensor into one of the output plugs and got a reading on both the +ve and -ve input wires.
regarding the chargers, its actually a charger (single unit that does up to 4 packs at a time, each one works independently from the next) and there is a reading of around 250k between port A and port B's negative terminal, 180k between their positives, and 150k between +/- on the same port.
this change anything?
bandaro
Postby fechter » Mon Sep 13, 2010 2:15 pm
That sounds good. I really don't know what's inside one of those, so best to do some testing first.
To be really careful, it might be a good idea to put a fuse in line with battery connections, at least for the inital test.
fechter
Postby bandaro » Tue Sep 14, 2010 3:09 am
ok, i was intending on poking around with the multi meter and watching the first few charges closely.
thanks heaps for your help fetcher, i can solder and stuff fine, but when it comes to matching/choosing components im at a total loss... should probly do a beginning electrical engineering course or something :P
bandaro
motor wiring help , please!
Postby robcamp » Sun Jan 30, 2011 4:24 am
i biught this motor and dont know what kind it is or the wiring diagram for it, i was told it is a 48v 500w brushless front motor. i need to find out what kind of controller i need and wiring how to hook it up pleas help here are some pictures. my email is rcampobasso@gmail.com if you can fwd any info, thnx
you can pm me info that would be great!!!
bike hub.jpg (28.04 KiB) Viewed 3891 times
robcamp
100 µW
100 µW
Postby bobc » Wed Feb 16, 2011 4:27 pm
Here is a circuit to connect a hall effect throttle (e.g. the longma twist grip sold for a few $ on ebay) to a radio control electronic speed controller.
It is a simple circuit, suitable as an early foray into electronics for those who have been frightened of it in the past!
It uses about 10mA current
includes a BEC (in case your ESC doesn't). If your ESC has a BEC in you can just leave that whole section off.
Output is a pulse every 20ms ranging from 0.7ms to 2.2ms in width
"Fairly" fail safe - total disconnection from hall throttle, and break in either the 5V wire or the signal wire will result in the motor stopping. disconnection of the GND wire alone will result in full throttle (the only fail-dangerous condition).
If you are worried - double up on the GND connections.
BEC part uses that old favourite the LM317 adjustable voltage regulator. With only 10mA load this can drop 30V without breaking sweat (that's 300mW) so I've specc'd a 35V electrolytic cap on the input. You can actually supply this from anywhere up your battery string from 8V to 35V.
ASTABLE part is a 555 timer configured in astable mode - signal 20ms should be a negative going pulse 250us wide every 20ms or so. Accuracy not essential here.
MONOSTABLE part puts the hall throttle signal into the 555 threshold input, so the output pulse width rises as the throttle signal voltage rises. This signal is passively pulled down for failsafe. Output pulse width is determined by the 18k resistor and associated 100nF capacitor. Considering that capacitor tolerances are not generally very tight, you may want to swap the 18k resistor for a slightly higher or lower value to get the pulse width just right. Basically, is the behaviour of the ESC acceptable? if it won't throttle down completely try a lower resistor; if you can't get full throttle try a higher value one. You'll be unlucky if the supplied values don't give full range ;^)
Here is the circuit put together on stripboard
There is, of course a dual 555 in one package called the 556 and it's probably cheaper and neater to use one of those - the component values stay the same but pin connections have to be translated. I just used what I had to hand.
It is easier to make and debug the circuit with the aid of a scope, but this one is simple enough to have a go without if you're feeling brave..... make the BEC first - ensure it's supplying 5V when the input is 8V and over. Then make the astable & confirm the 20ms timebase. Then make the monostable part.
Just to make clear what the various plugs are:
X1 is 8V to 35V supply for if your ESC does not have a BEC - you can connect this to the bottom few cells of your main battery. It only takes a few mA so the extra dreain on those bottom cells is negligible.
X2 connects to the hall throttle Signal, 5V and GND
X3 is a shutdown input. This is to allow a battery monitor (eg the celllog from HK - hint hint) to stop the motor from utterly discharging your lipo's... It is configured to connect to an "open collector" or dry contact.
X4 is the "servo drive" connection to the ESC Signal 5V and GND
bobc
Postby icekreme1002 » Wed Aug 24, 2011 8:07 am
Hey guys.
I am very new to the electronics world and have started work on a 18s balancer using fan cooled resistor modded battery medics, and cell-logs for hvc. I appoligise now, for how neewbish this is probably going to be....
So far I have completed most of the design, and the hvc and balancing are working wonderfully. But I have come a little stuck with how to power the fans.
Ideally I would like to use a 3p2t switch and have the choice between running the fans from the individual packs, or from the 12v supply that powers my fans and display for my meanwells.
Like i said I am very new to all this, but i'm pretty sure the common ground in my circuit between the packs and 12v supply is whats causing the problem and magic smoke.
Here's an abbreviated terribly drawn version of what im trying to do.
So i already fried a jst connector on the 7th pin so im pretty sure its the ground because it all in parallel or whatever.... what can i do to stop this?
Is there an easy way to prevent the short circuit using schottys or something?
I really dont know where to go from here or what to try and still keep the whole thing simple so any advice or ideas from you guys would be awesome.
I could always choose just the power supply or just the battery packs to run the fans but wheres the fun in that? haha
Thanks for any help guys :-)
1st build - Norco Hardtail, 18s Lipo, HS3540, Lyen 18fet 45/120amps
http://endless-sphere.com/forums/viewtopic.php?f=6&t=32041
icekreme1002
Postby fechter » Wed Aug 24, 2011 8:47 am
The negative wire from your 12v power supply is going to both packs (I think). This will be shorting the bottom pack and make smoke, etc. You could disconnect the packs from each other to solve this, or better would be to use two separate switches, one for each fan.
Here is a badly hacked diagram showing the top setup. The bottom one could be wired the same way. With the switches in this configuration, the 12v supply is never connected to the packs.
(30.87 KiB) Downloaded 39 times
fechter
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: chroot, pschmatz and 14 guests
