Jozzer wrote:Any easy circuits to be made to handle adjustable low voltage cutoff for a pack discharger?
And on a similar note, an adjustable max voltage cutout for charging?
Bonus points for a cicuit that does both
bobmcree wrote:as justin pointed out to me, the ebrake line can be used as the input for the pull-down current/speed limiter. the ebrake input is connected to the throttle line through a diode and 10k series resistance, so the control line from the limiter, or any other device that functions by pulling down the throttle signal, can simply be connected to the ebrake line without the need for any additional circuitry. additionally, the thermal cutout on the pcb is connected to this line. the thermal cutout simply grounds the throttle signal when the board overheats. this way it is not necessary to switch large currents directly.
Jozzer wrote:Sounds like a start Bob, but I'll need more than that to get going![]()
Jozzer wrote:I'll bear that in mind. I have a nice relay here, but its coil is towards the higher end of your recomendation. I've ordered one that uses half the power, I hope that will do it.
Bits should be here tomorrow, I look forward to having a go at it. Bench testing and improving it should keep me busy for a few days/weeks![]()
Will this circuit work with any voltage pack thats within spec (think the transisters were rated 40v)? I realise the cuttoffs would need recalibrating..
Jozzer wrote:The circuit is built, apart from the 12v regulator which I have just ordered.
I've reread your last post a few times, and cant see that you answered...the three connections terminating in triangles/arrows in your diagram are grounds? Do they just ground to each other, or are they connected to the pack negative? I apologise if you answered indirectly and I missed the point...
Thanks very for your help, it's a bit late in life to be taking the first steps in electronics, I can't believe to this day that none was taught to me in school, or that to this day I've not applied myself to the task of learning. Call it my midlife crisis, but thats going to change! Seeing how easily you/Fetcher can achieve the results you seek has been very inspiring.
bobmcree wrote:there are no dumb questions...
Toorbough ULL-Zeveigh wrote:there are only dumb question askers.
Aren't there?
Why aren't there?
Can you prove that?
Toorbough ULL-Zeveigh wrote:This kind of evidence:Aren't there?
Why aren't there?
Can you prove that?
There was a secret purpose behind Xysters Dumb questions, you'll notice he now has more than 3000 posts
Jozzer wrote:Thanks again Bob, think I'm ready to test once the 7212 gets here![]()
Users browsing this forum: No registered users and 12 guests
