Hi! Can I use this Kelly KBS72051,20A,24-72V BLDC Motor Speed Controller for Fisher and Paykel Motor?
KBS programmable BLDC motor controller provides efficient, smooth and quite controls for electric motorcycle, golf cart, go-cart, as well as industry motor speed or torque control. Motor speed controller uses high power MOSFET, PWM to achieve efficiency 99% in most cases. Powerful microprocessor brings in comprehensive and precise control to BLDC motor controllers. This programmable brushless motor controller also allows users to set parameters, conduct tests, and obtain diagnostic information quickly and easily.
Provide free male or female connectors matching with KBS controller.
Features:
• Intelligence with powerful microprocessor.
• Synchronous rectification, ultra low drop, fast PWM to achieve very high efficiency.
• Current limit and torque control.
• Battery current limiting available, doesn’t affect taking off performance.
• Low EMC.
• LED fault code helps user debugging.
• Battery protection: current cut back, shutdown and warning at high or low battery.
• Thermal enhanced rugged aluminum housing. Rugged connectors.
• Thermal protection: current cut back on low temperature and high temperature to protect battery and controller.
• Configurable 60-degree or 120-degree hall position sensor.
• Support any number of poles.
• Up to 40000 electric RPM. (Electric RPM = mechanical RPM * motor poles)
• Three modes of regen: brake switch regen, release throttle regen, 0-5V signal regen.
• High pedal protection: Disable operation if power up with non-zero throttle.
• Current multiplication: Take less current from battery, output more current to motor.
• Easy installation: 3-wire potentiometer will work.
General Specifications:
•Frequency of Operation: 16.6kHz.
•Standby Battery Current: < 1mA.
•5V Sensor Supply Current: 40mA.
•Supply Voltage: PWR, 18V to 90V for controllers rated equal or lower than 72V. 8V to 30V for 24V controller.
•Supply Current, PWR, 150mA.
•Operating Voltage, B+, 18V to 1.25*Nominal Voltage.
•Analog Brake and Throttle Input: 0-5 Volts. Can use 3-wire pot to produce 0-5V signal.
•Reverse Alarm, Main Contactor Coil Driver, Meter: <200mA.
•Full Power Operating Temperature Range: 0℃ to 50℃ (controller case temperature).
•Operating Temperature Range: -30℃ to 90℃, 100℃ shutdown (controller case temperature).
•Motor Current Limit, 1 minute: 50A.
•Motor Current Limit, continuous: 20A.
•Max Battery Current :Configurable.
