Anybody know spoke sizes for the new xlyte motors?
if your talking about the HT/HS series then your looking at 12ga or 13ga depending on production date...
disndat said:
Hi I am putting together a 24" rear high speed version of the new xlyte motor.I know ebikes has a spoke calculator but I dont know what the dimensions are of the rear hub.Any help is appreciated.
Thanks
If you are using standard spoke calc, here are the basic number that you need for HS3540 rear motor:
dL 232mm(diameter Left)
WL 16.5mm(hub width left)
dR 232 mm(diameter Right)
WR 17.5mm(hug width Right)
Ken
