72v 1500W 40A Hua Tong CA08 XM06AD_P04.1 controller
Re: 72v 1500W 40A Hua Tong Generic controller connections
Postby iovaykind » Mon Aug 22, 2011 9:12 pm
Most of the plugs you'll need to resolder with the connections you'd like other than maybe the hall sensor plug.
Winter needs to end already!
iovaykind
Postby wesnewell » Tue Aug 23, 2011 1:05 am
Mine came with ring terminals for power and phase wires. Forgot the others. I just cut off and replaced the ones I used with the connectors I wanted anyway.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby bobale » Tue Aug 23, 2011 8:55 am
Iovaykind, did you recieve my PM about this controller?
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby iovaykind » Tue Aug 23, 2011 9:27 am
Replied.
Gonna see if I can open up the controller today to work out the three speed switch. Is it simply grounding x1 vs x2 vs x3 to get the three different speed options?
iovaykind
Postby PeeHell » Tue Aug 23, 2011 12:47 pm
Wow if you guys get the 3 speed switch to work that would mean this controller is a steal (32$) !
Does anyone has had any issues or negative experiences with it thus far ?
PeeHell
Postby Black6spdZ » Tue Aug 23, 2011 3:37 pm
Decided to open my controller up and get some pics.. maybe we can brainstorm and find more advanced features of this unit.
15x IRFB4410 N-Channel MOSFETs
Drain to Source Voltage (Vdss) 100V
Current - Continuous Drain (Id) @ 25° C 96A
Rds On (Max) @ Id, Vgs 10 mOhm @ 58A, 10V
Power - Max 250W
1x 1000uF 100v Filter cap
2x 470uF 100v Filter caps
yellow/white stripe 60/120 phase wire lands on pad M4
brake wire lands on pad SH
cruise on pad ZL
speed sensor on pad SD
It appears the phase wires have been installed incorrectly, the motor phase outputs yellow, blue and green are installed on pads marked U,V and W where as the Hall phase wires blue lands on U pad, green on V and yellow on W.
my guess is the M1-M3 pads are speed and reverse functions.. I will experiment a little later
X and XL pad on topside regen?
(145.29 KiB) Downloaded 85 times
(159.4 KiB) Downloaded 85 times
(118.4 KiB) Downloaded 85 times
(120.36 KiB) Downloaded 85 times
(138.98 KiB) Downloaded 85 times
(126.31 KiB) Downloaded 85 times
(138.61 KiB) Downloaded 85 times
(145.61 KiB) Downloaded 85 times
(151.27 KiB) Downloaded 85 times
(130.95 KiB) Downloaded 85 times
(149.07 KiB) Downloaded 85 times
(124.57 KiB) Downloaded 85 times
Black6spdZ
Postby Rumberopie » Fri Aug 26, 2011 10:45 am
Hi guys,
After your test, what are the maximum specifications of this controller?
I can go at 24s lipo (max 100,8v) 40a with this controller.
I would like to use it with my 48v1000w conhismotor.
You think its ok?
Sorry for my terrible english.
Rumberopie
Postby iovaykind » Fri Aug 26, 2011 12:03 pm
The controller has 100v caps so 24s fully charged may be pushing it. Though with voltage sag you should be alright, I wouldnt' try it myself but its such a cheap controller might be worth testing to see if it'd work.
iovaykind
Re: 72v 1500W 40A Hua Tong CA08 XM06AD_P04.1 controller
Postby wesnewell » Fri Aug 26, 2011 2:05 pm
Mine handles anything from 18-24s without a problem. At 24s with 1000W motor, the speed and power isn't for the weak of heart. At 24s the throttle gets touchy and takes a lot of practice to take off without jumping, but you get max speed with it.
wesnewell
Postby nieles » Fri Aug 26, 2011 3:08 pm
for everyone with one of these controllers, do not stress the fets too much.
the fets are stamped fb4410 instead of irfb4410, so this tells me the fets are fake
which is not really suprising considdering the cost of the controller
(i also have one btw)
nieles
Postby kentlim26 » Fri Aug 26, 2011 3:39 pm
the hua tong 72v 1500watts is it only really 15fets ?
i think im quite happy to stay with 48v 2000watts on the cyclone motor. the torque is very good and pick in 50km/h in just few seconds. the 48v 2000watts is a 18fets, i don't know if the fets are real or fake. if this thing, hua tong can let me run more then 5500km, i can say this controller better then the Orginal cyclone controller 1200watts. so i don't know, i have to run controller 48v 2000watts as far as i can. to find out how reliable is it.
for not more then 5000km , i have run and blow afew cyclone controller. They were orginal and expensive, 2 or 3times the cost of hua tong. sure i can't survive like that,, ha ha. so i have to test them and see the result and find out.
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Postby Black6spdZ » Fri Aug 26, 2011 3:49 pm
nieles wrote:for everyone with one of these controllers, do not stress the fets too much.
Correct me if my calculations are wrong, but I measured 0.3 ohms between each of my phase windings on my 48v 1000w motor. So if your supply was a consistent 72v / 0.3 ohms the max current between each phase would be 240 amps. If this current was shared between 5 Fets such as this controller each would have to carry 48 amps.. well within a 96A tolerance... and thats if the power was held on 100%.. but it is pulsed and modulated so never would see that amount of current.. besides the controller will power down the motor if it detects its stalled anyway.
Black6spdZ
Postby wesnewell » Fri Aug 26, 2011 5:23 pm
They aren't fake, otherwise they wouldn't work. Check the International Rectifier website and you will find that IR is not part of the part number stamped on parts. Are these made by IR? Don't know. Don't care. Didn't look close enough. Wait, I've got one open.... Why yes they are The IR logo is below the part number. Not that it makes a bit of difference. They could still be fake.:-)
wesnewell
Postby Black6spdZ » Fri Aug 26, 2011 6:25 pm
According to the datasheets still, they can handle 380 amps with a pulsewidth of 20% as long as you keep the junction temp lower than 175d C. With active cooling I think the controller would long outlive the motor windings!
Black6spdZ
Postby bobale » Fri Aug 26, 2011 7:37 pm
Well as they are cheap, you may as well try 24S just for the fun of it, but I gess both FETs and caps won't that long on that high voltage. Even if you charge your LiPos to 4.1V you'll be still dangerously close to max rated voltage for both components.
BTW, just ordered one :mrgreen:
bobale
Postby nieles » Fri Aug 26, 2011 8:56 pm
wesnewell wrote:They aren't fake, otherwise they wouldn't work. Check the International Rectifier website and you will find that IR is not part of the part number stamped on parts. Are these made by IR? Don't know. Don't care. Didn't look close enough. Wait, I've got one open.... Why yes they are The IR logo is below the part number. Not that it makes a bit of difference. They could still be fake.
viewtopic.php?f=2&t=10655&hilit=counterfeit
please read the first 2 pages of this thread. there is a statement there are no fb4110 fets produced by IR.
i know this is about 4410 fets, and the other thread is about 4110 fets. but the same story applies for the 4410 fets i think
what the difference is, they probably will not handle the current they are rated for in the specsheet
Black6spdZ wrote:Correct me if my calculations are wrong, but I measured 0.3 ohms between each of my phase windings on my 48v 1000w motor. So if your supply was a consistent 72v / 0.3 ohms the max current between each phase would be 240 amps. If this current was shared between 5 Fets such as this controller each would have to carry 48 amps.. well within a 96A tolerance... and thats if the power was held on 100%.. but it is pulsed and modulated so never would see that amount of current.. besides the controller will power down the motor if it detects its stalled anyway.
the current is shared by 2 fets. (i think on the high side)
the current is shared by 3 fets on the low side (or the other way around)
as an example:
the current goes from the + of the battery to the high side fets(phase A)
the current goes through the motor coils
the current goes from the low side fets (on phase B) to the battery -
this is 1 step from the 6 step commutation in a brushless controller.
nieles
Postby wesnewell » Sat Aug 27, 2011 12:43 am
I'm not wasting any more time on this fake or not fake fet crap because I really don't care one way or the other. What I do know is that it will handle over 100V input from the battery pack because I've put over 100V on it. No ones twisting your arm to buy one.
wesnewell
Postby Black6spdZ » Sat Aug 27, 2011 2:24 am
as an example:
I believe you are correct sir.. first half of the cycle the perm mags are attracted by two FETs then attracted by three.. this is ok because the pulsewidth is halfed again.. we can still draw 380 amps per fet with 20% DC. Lets find if the M1-M3 contacts have power adjustments or regen cabailities.
Black6spdZ
Postby iovaykind » Sat Aug 27, 2011 7:20 am
+1 on the m1-m3 capabilities. who's been pioneering these testings?
iovaykind
Postby iovaykind » Sun Aug 28, 2011 5:24 pm
Any ideas on high voltage regen also?
iovaykind
Postby Black6spdZ » Sun Aug 28, 2011 10:36 pm
Here we go guys.. did some testing tonight with the bike flipped upside down and found a few things...
pad M2 to ground is low power mode.. I'm guessing about 60% from the speed decrease at WOT
pad X is regen braking.. with wheel spinning WOT and ground this pin voltage jumped higher than batteries resting voltage and wheel came to a pretty quick hault
grounding pads DS and SL just seem to disable the motor.. like a kill switch
ground pad SX seems to function like another low power mode like M2
pad M1, M3 and DS dont appear to have any function
had to swap U and V phase wires and V and W hall wires to get the motor to run correctly
Black6spdZ
Postby iovaykind » Sun Aug 28, 2011 11:05 pm
M2 is low power mode, sweet!
How come later on in the post you said M2 doesn't have function? I think you meant M3?
iovaykind
Postby jonathanm » Sun Aug 28, 2011 11:07 pm
Black6spdZ wrote:pad M1, M2 and DS dont appear to have any function
You mean M3, right? good info, thanks for checking that out.....
jonathanm
Postby Black6spdZ » Sun Aug 28, 2011 11:33 pm
sorry.. typo.. yes M3 doesnt have a function.. M2 is low power mode
Black6spdZ
Postby wesnewell » Mon Aug 29, 2011 2:46 am
Thanks Black6spdZ. The way you swapped hall and phase wires through me until I noticed that U and V phase are yellow and green, and W and V hall wires are also yellow and green. There are lots of other pads. Did you try any of them? Also, what size battery pack were you using when you tested regen, and how much did the voltage jump? Looks like I'm going to have to dig up some more toggle switches.
wesnewell
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: Drunkskunk and 14 guests
