72v 1500W 40A Hua Tong CA08 XM06AD_P04.1 controller
Re: 72v 1500W 40A Hua Tong CA08 XM06AD_P04.1 controller
Postby cohberg » Mon Oct 17, 2011 11:24 am
mauimart wrote:Just got this controller working
mauimart, please could you tell us what the green plug and extra red plug do? We were guessing 3 speed switch and regen/abs
Build 5.0 - Commuter (Active) | 18xIRFB4115@50A | 30S2P 10Ah | GM Rear Hub | V2100 | CST-Cyclops | XC 28
Build 5.1 - Chain Virgin (Halted) | HPM5000B | 11.4:1 reduction ( 12:32 - 9:38) | HPC300 72V300A | 20S5P 25Ah
cohberg
Postby PeeHell » Tue Oct 18, 2011 6:39 pm
I think we sould start a new thread about "greentime controller" if it hasn't been done yet...
PeeHell
Postby jk1 » Tue Oct 25, 2011 5:17 am
I notice auraslip said he modded the LVC down on these hua tong controllers but i can't for the life of me find the details of how it was done ! was it this thread or another huatong thread as i have seen several threads recently on these controllers
jk1
Postby Gordo » Tue Oct 25, 2011 9:21 am
jk1 wrote:I notice auraslip said he modded the LVC down on these hua tong controllers but i can't for the life of me find the details of how it was done ! was it this thread or another huatong thread as i have seen several threads recently on these controllers
I put "hua tong auraslip" in the search box and this is what came up. Hua Tong is 2 words, like John Smith. I too find this search engine very lame and spend hours trying to find things.
viewtopic.php?f=2&t=26306&p=464973&hilit=hua+tong+auraslip#p464973
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby wesnewell » Tue Oct 25, 2011 11:04 am
Changing the LVC in a 72v generic controller
viewtopic.php?f=2&t=26306&hilit=changing+lvc#p376677
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby stewrobb » Wed Nov 02, 2011 10:21 pm
Okay, so I just received the Greentime controller, and I must say am very impressed (although it took like 40 days). The jittery behaviour I felt from starts and at certain throttle ranges with the hua tong are non existant with this controller, very deliberate. The current seems a lot higher, but I don't have a wattmeter to give an exact figure, they say 45 or 50A, depending where you look, I suspect it's closer to the 50 range.
What was extremely interesting to me is the connections used for regen braking, If you look at my earlier post, with my Hua Tong, I used X and got reverse current, albeit for a short moment until the phase wires were shorted out, which told me that it was capable of regen, although I couldn't figure it out. On this Greentime, the regen is activated by connecting DS and X. I am super busy with midterms and such, so I won't have the chance to try this out on my Hua Tong (x may have to be connected to something other than DS), but if any of you folks want regen(very redundant), my suggestion would be to try connecting x to something other than GND, I would bet money that this is the ticket. It is activated when a brake signal is present.
https://picasaweb.google.com/1046734498 ... directlink
Good luck, hopefully someone else will carry on the regen flame and finish the race for everyone still using a Hua Tong!
Gio 500+ scooter - @72v 50A X8M06 Greentime Controller
Delta/Wye - Regen - 20s3p 20c Turnigy hardcase
- Drove until the end, bent frame retired it
Current Build:
Ironhorse Hardtail frame, 120mm Suspension
Front Hayes Hydro Disc, Rear cable Disc
18 FET 4110 60A (for now) Controller
1000w Rear Motor - 420rpm@48v
20s3p Turnigy 5Ah
stewrobb
Postby cohberg » Wed Nov 02, 2011 10:25 pm
sd as in the throttle input?
cohberg
Postby stewrobb » Wed Nov 02, 2011 10:59 pm
Thanks, I made a mistake with the connections, they have been fixed
I spoke to the seller, and he actually gave me a list of all the pads and what they do. Great guy. I have put them on my picasa as well. The seller clarified "K1 K2 dial gear", you connect them together to advance timing for a slight speed boost. This is seriously the best china controller I have ever used, It has all the function you see in the image, plus 3 speed, and cruise. Everything is as it should be, regen is powerful yet smooth (running on 72v SLA's). The MOSFETS are 4410's rated to 100v. The seller was absolutely wonderful, and answered all of my questions within minutes. Shipping took a long time, but it was because it was held up at customs, so I guess I got unlucky. For $50, it is 100% the best bang for you buck.
Current Build:
20s3p Turnigy 5Ah
stewrobb
Postby wesnewell » Thu Nov 03, 2011 2:25 am
It's great that you like your greentime controller, but why is it in this thread? For this controller, X connected to ground IS rengen braking. Posting info on your conbtroller in this thread just confuses things. Please start you own thread to discuss your controller.
wesnewell
Postby stewrobb » Thu Nov 03, 2011 9:12 am
well because I have previous history with my other Hua Tong posts, didn't realize it had been split up. people were awaiting my response here. fair enough. So what I am wondering is are all Hua Tong's without regen after a certain date, or do some sellers on dhgate sell this one, and if so who? thanks,
Stew
Current Build:
20s3p Turnigy 5Ah
stewrobb
Postby wesnewell » Thu Nov 03, 2011 10:56 am
stewrobb wrote:well because I have previous history with my other Hua Tong posts, didn't realize it had been split up. people were awaiting my response here. fair enough. So what I am wondering is are all Hua Tong's without regen after a certain date, or do some sellers on dhgate sell this one, and if so who? thanks,
Stew
There's at least 3 different models being sold as a 72v 1500W 40A Hua Tong OT100 controller. I have 2 of the original ones per subject line. I'm not sure as to the status of the other 2. I would suspect that they all support regen braking and it's just a matter of finding out how to enable it in the controller.. I've read it's not with the X pad on the one with the 4710 fets. Regen braking will not work on any of the stock ones if you use higher than standard voltage battery packs. It won't work with fully charged 20s lipo. It does with 18s. LVC is about 60V on this controller, so 18s works out perfectly for both regen and pack protection.
wesnewell
Postby stewrobb » Sat Nov 05, 2011 11:34 am
Good to know, I wonder if the same sellers have different models. Isn't the regen voltage proportional to the lvc? I am about to start running my 20s packs that I am building and require regen (broken rear drum brake). I hope this will be adjustable. Thanks
Stew
Current Build:
20s3p Turnigy 5Ah
stewrobb
Postby cohberg » Mon Nov 07, 2011 6:40 pm
At risk of being yelled at by wesnewell, I just got the new board and the new plugs are reverse (black green) and three speed switch (brown black red).
Going to replace the caps, vr circuit and mosfets and try to get support for 150V: wish me luck :D
cohberg
Postby dbaker » Mon Nov 07, 2011 8:35 pm
150 volt :) Ambitious :mrgreen:
dbaker
Postby wesnewell » Tue Nov 08, 2011 3:29 am
cohberg wrote:At risk of being yelled at by wesnewell, I just got the new board and the new plugs are reverse (black green) and three speed switch (brown black red).
No yelling, but you should open it up and document what you have, board number, caps, fets, etc. if it's a different board, then you should start a new thread with it's number in the subject. I haven't seen one with the 3 speed switch and reverse connector coming out. I'm sure if you document where the wires go from those connectors, it will help someone. Would really be nice if it has this pcb in it.
wesnewell
Postby caleb » Wed Nov 09, 2011 1:56 pm
I read this thread and ordered this controller, but it arrived with extra wires than what is described in page 5 post. I tried to wire it up and it does not work. The throttle position wire I believe may be backwards or something else needs to be plugged in? I have 5 wire hall sensor plug, 3 wires to motor, and 3 wire white colored plug to thumb throttle, and ignition RED wire connected to positive on battery. Is there anything else needed to be connected to operate controller? ...what do the other red plugs do?
I checked the controller with this http://www.ebay.com/itm/NEW-Portable-E-bike-Brushless-Motor-Controller-Tester-/250919544203?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D250905322582%26ps%3D63%26clkid%3D4078499369340164742#ht_3904wt_1185 and it doesn't respond to thumb throttle. I bought a new controller because old one would overheat and stop driving the hub motor properly, losing power and studdering until it would not work.
caleb
Postby cohberg » Wed Nov 09, 2011 4:58 pm
edit: the throttle is a white plug. did you mix it up with the 3 speed (red plug | brown, black, red)?
I believe that the throttle is wired up like regular. Green is sense, black is GND and red is +5V. Also something that might help is to pull the controller apart and look for the status LED. It'll tell you via blink code what the problems (if any) there are.
caleb wrote:I checked the controller with this http://www.ebay.com/itm/NEW-Portable-E- ... 904wt_1185 and it doesn't respond to thumb throttle.
I don't really know what specific fuctions your tester has, but if anything i don't think you would testing your controller. You should be testing your throttle/hall/phase to see if it is functioning normally. Not the other way around.
Maybe i'm just understanding you wrong but the way i test is i get a 10K pot and just use that as my simulated throttle, less variables I guess.
caleb wrote:what do the other red plugs do?
As to the other red wires the 4 (3 populated) pin is alarm the 2 pin is pack voltage and the 3 pin is speed switch.
iovaykind labeled it all minus the new plugs
cohberg
Postby bobale » Wed Nov 09, 2011 8:27 pm
On mine HuaTong throttle connector was wired up wrong way, so I had to swap black and red to get it working.
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby caleb » Fri Nov 11, 2011 12:15 am
here is my controller
ebike controller.jpg (153.17 KiB) Viewed 774 times
i tried to switch red and black wires on throttle controller 3-pin connector. I cannot get the motor to spin...any other ideas? I am only using 48-60 volts currently, does that matter on this 72V controller? I have 12s or 14s lipo configuration.
I am plugging in:
5 pin sensor motor wires
3 pin thumb throttle
3 phase wires to motor
2 pin voltmeter
1 bare red wire thought to be "ignition" or torn ON switch tied to battery positive
2 ring terminals red/black to battery plug (now deans connector)
not sure why its not working...
thanks for reviewing and any ideas...next idea is to disassemble and review wires on circuit board. but i still don't have a diagram showing what goes where yet.
edit - right side of photo yellow block should say "3wire to thumb throttle"
caleb
Postby cohberg » Fri Nov 11, 2011 12:33 am
If you're using 12s or even 14s i believe that you're hitting LVC.
cohberg wrote: pull the controller apart and look for the status LED. It'll tell you via blink code what the problems (if any) there are.
8 blinks in a row is lvc.
It be helpful if you listed what you have (motor, throttle, etc)
cohberg
Postby kentlim26 » Fri Nov 11, 2011 1:10 am
You need at least 16cells or 18cells. volts supply must be above 75v to see motor runs smoothly. when the battery volts is supply 60v or 62v will power off - with this 72v controller. since this controller can accept 80v, it will be definitely alot of interesting and FUN !!
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Postby wesnewell » Fri Nov 11, 2011 2:31 am
caleb wrote:i tried to switch red and black wires on throttle controller 3-pin connector. I cannot get the motor to spin...any other ideas? I am only using 48-60 volts currently, does that matter on this 72V controller? I have 12s or 14s lipo configuration.
It won't work on anything less than 15s lipo (63V). I'd consider 18-20s optimum and 24s the max. I run a 10ah 18s pack and a 5ah 24s pack.
wesnewell
Postby Finzent » Fri Nov 11, 2011 5:07 am
Mine cutted off slightly below 63 volt before changed the lvc resistor to 2k, now the cutoff comes in about 36V. :)
Finzent
100 µW
100 µW
Postby kentlim26 » Fri Nov 11, 2011 5:57 am
which is the resistor is the LVC , i will like know. how how to change them ? kindly show some photos so, i will really like to try it out. i think is really good for us, everyone will like to try out lower voltage 48v pack.
thanks !
kent
kentlim26
Postby Finzent » Fri Nov 11, 2011 6:12 am
kentlim26 wrote:which is the resistor is the LVC , i will like know. how how to change them ? kindly show some photos so, i will really like to try it out. i think is really good for us, everyone will like to try out lower voltage 48v pack.
thanks !
kent
viewtopic.php?f=2&t=31946
Changed the resistor A from 1.2k to 2k, the first link has the pictures and from there the third photo has the marks for A and B. :)
Remove the smd resistor(1201) and replace it with standard thread or film resistor.
I've tested the controller on table with adjustable voltage supply and tomorrow it'll go to my e-scooter(48V or 60V, haven't decided yet).
Finzent
100 µW
100 µW
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: botz244, Google [Bot], johnjcbs, slbaker and 11 guests
