cwah wrote:Ok, finally opened the controller.
On this side we can see the "x pad" without anything:
Not sure how to make sense of this for regen or ebrake lol
wesnewell wrote:cwah wrote:Ok, finally opened the controller.
And here lies the problem. That is NOT the CA08 XM06AD_P04.1 controller PCB. It is a later model. This is the CA08 XM06AD_P04.1 controller PCB.
flez1966 wrote:Damn...
When i found this thread I thought I had found the answers!
my controller is a chip/pcb by bolee and then its populated with fets elsewhere and sold, seems to match 90% of whats in this thread but.........
on the bench its running fine, take it out and after 10-15 seconds it trips out.. this 10-15 seconds gets shorter and shorter till its like only 3-5 seconds, and I get 7 flashes.....
oh well.....
Paul.............D wrote:flez1966 wrote:Damn...
oh well.....
Check your battery voltage to make sure it is not sagging under load to low voltage cut off.
Paul
knighty wrote:just checking it's ok to leave these controllers connected 24/7 and turn them on/off with the ignition wire/switch...
no power drain etc... ??
wesnewell wrote:knighty wrote: It doesn't use much, but will ruin your battery by draining it to 0V over time.
kentlim26 wrote:I think it advice better don't. Just add a power switch Box. Just off it !. By just going to connect power all the way to controller, I think the controller will have some Heat. can try for few hours and see , if the controller stay hot or not. as for me, i will not do that. So far, i have never read anyone says " I put my power to the controller 24/7.. will this really damage the caps silently. ? or will it really blow? Must see who has done that ?
kentlim26 wrote:thanks. i solve the in rush current by going throu a resistor 10watt 100ohm and you will see spark, noise will be entire gone. 48v ~ 65v it works. i have also try 98v throu a 10watt 200ohm, i think the spark will be gone, but this i haven't find out yet. some will use mosfets and build a circuit to the controller, soft switch. i hope you can try to find this out regarding about this 10watts 100ohm, or 200ohm, and there i build inside a switch Box no2. is a main power into the controller = hence No more in rush current
ken
kentlim26 wrote:i really did that , Half eye closed..
Users browsing this forum: miro13car, StanSimmons and 6 guests
