oatnet
I bought this Sunstone Engineeering CD375DP dual pulse 375ws spot-welder on ebay for $600 a few months back, including foot-pedal, spot-welding leads, and wire-weldiong leads (on top). It came with the pictured pyramid power supply which recharges the caps really fast.
Nickel strip/sheet is expensive, so I farted around a long time before... jimw1960 posted on this thread http://www.endless-sphere.com/forums/viewtopic.php?f=8&t=28208&p=406657 a link to a123RC's website, where they were selling 0.2mm x 10mm (@ 0.008 x .40") nickel strip at a ridiculously cheap $2.59/meter. I took the plunge and bought 15m from this link:
http://a123rc.com/goods-268-1m+Pure+Nickel+Soldering+Tabs+For+Battery+26650.html
I didn't properly register the thickness; I was think .002", not .2mm. I was looking for .005", but I thought maybe I would layer 2-3 strips to .004" or .006", so I bought 3x more than I thought I might need. Now I have plenty of strip to play with.
This weekend I experimented on a 0v a123 M1 cell. .008 was a little bit thick for this welder. On the first go, it made welds that stuck, but not as strongly as I would like. I pulled off the tab and tried it on the other side, this time zapping each weld twice. These welds stuck, hard.
I wonder if I simply parallel the bank of the caps I assembled for my "<$100 resistance welder" project, I can increase the WS enough to punch through .008 with one zap. I have some molybednum rod I machined a ways pack for the same project, and maybe some 4gua leads, to upgrade the welding leads, that should help too.
I have a huge quantity of a123 1.1ah cells in 18v dewalt packs that I got from Doc, really cheap, a ways back. Next I need to try welding to the factory tabs that parallel each pair of these cells, I can fit 2 maybe three strips wide across those cells, enough to take a good amount of current. If it sorts out, I'll be making piles 'o discount cells for random applications... like one of the "Vector VEC012APC Start-It Elite Jump Starter and Power System" I bought in 2007, whose Lead-acid battery has died. I was going to replace the Pb, but I'll slap in as much a123 as I can fit, resolve the self-discharge woes and have be able to start, inflate, and light up entire fleets of vehicles between charges. :lol:
EDIT: replace pictures that seem to have disappeared
