auraslip wrote:.... these chargers are not only $12. Even direct from King Pan in bulk they come out to around $50 a piece.
Hillhater wrote:![]()
who mentioned $12 ?
I could go down to 48.52 V, after that trimmer starts to click not allowing going further.
bionx 1954 wrote:I have on off the chargers that have a label with various voltage marked and a check mark at 43.5 V, I opened it up by removing the end srews (4 per side) and the top of the aluminium cover lifts off. The voltage trimmer is near the panel fuse, It adjust to all voltages that are marked on the case. it is a lot like Lyens DC/DC trimmer pot.
bionx 1954 wrote:The voltage trimmer is near the panel fuse, It adjust to all voltages that are marked on the case. it is a lot like Lyens DC/DC trimmer pot.
parabellum wrote:Just giving the picture like it is. On the 3rd pot I only did 1.5 rev in each direction. maybe there is still hope?
From other side.bionx 1954 wrote:The voltage trimmer is near the panel fuse, It adjust to all voltages that are marked on the case. it is a lot like Lyens DC/DC trimmer pot.
1)What voltages are marked on the case?
2)What is the lower and higher limit?
PetriK wrote:I have had one of these too for some months and have used the voltage adjustment to optimize the volts for my pack depending on the need.
Only today found this post, so:
The middle adjustment you say is charge current ?
And the third is for ?
Floont wrote:
I'm looking at a similar charger at http://www.bmsbattery.com/alloy-shell/28-alloy-shell-900w-lifepo4li-ionlead-acid-battery-ev-charger.html
My 30s3p pack of Lipo calculates out to 111volts at the flat 3.7v part of the battery curve, but when I charge them I need to go to 4.15v per cell which calculates out to be 125volts for the charger.
I'm curious if the trim pots in the charger has enough range up or down from their nominal voltage to get me to the voltage I need. Or will they just send me a charger that puts out 125VDC. Also, I have this fear of over-charging them accidentally if it trickles current after they've reached the set point voltage.
Also, the shipping is almost as much as the product!
my trim pot managed to go from 48.52 V to 63V (I did not tried more because of caps limit). It was as requested preset to 50.4V.
BMS battery has very rare shipping policy and time and offer to change shipping method or paying more after 1 week after order just killed me.Have 10 more of this chargers on the way, not from BMS.
Floont wrote:Can I get an identical charger as the one above from another source without buying 10?
parabellum wrote:...He also seems to understand English.
parabellum wrote:Floont, how many W are you looking for?
Floont wrote:
I have changed the cart on BMSbattery.com to a 2000W 125VDC charger, so I can get a 10amp charge.
I don't want to spend my waking hours waiting on LiPo batteries to charge.
parabellum wrote:Floont wrote:I have changed the cart on BMSbattery.com to a 2000W 125VDC charger, so I can get a 10amp charge.
You know, your 120V sockets are 1650W max and it seems not to be underrated. I have successfully melted 2 sockets at home by connecting portable Air Conditioner 1600W rated.
Users browsing this forum: a4178, amberwolf, justforfun and 14 guests
