Floont wrote:
I'm looking at a similar charger at http://www.bmsbattery.com/alloy-shell/28-alloy-shell-900w-lifepo4li-ionlead-acid-battery-ev-charger.html
My 30s3p pack of Lipo calculates out to 111volts at the flat 3.7v part of the battery curve, but when I charge them I need to go to 4.15v per cell which calculates out to be 125volts for the charger.
I'm curious if the trim pots in the charger has enough range up or down from their nominal voltage to get me to the voltage I need. Or will they just send me a charger that puts out 125VDC. Also, I have this fear of over-charging them accidentally if it trickles current after they've reached the set point voltage.
Also, the shipping is almost as much as the product!
my trim pot managed to go from 48.52 V to 63V (I did not tried more because of caps limit). It was as requested preset to 50.4V.
BMS battery has very rare shipping policy and time and offer to change shipping method or paying more after 1 week after order just killed me.Have 10 more of this chargers on the way, not from BMS.
Floont wrote:Can I get an identical charger as the one above from another source without buying 10?
parabellum wrote:...He also seems to understand English.
parabellum wrote:Floont, how many W are you looking for?
Floont wrote:
I have changed the cart on BMSbattery.com to a 2000W 125VDC charger, so I can get a 10amp charge.
I don't want to spend my waking hours waiting on LiPo batteries to charge.
parabellum wrote:Floont wrote:I have changed the cart on BMSbattery.com to a 2000W 125VDC charger, so I can get a 10amp charge.
You know, your 120V sockets are 1650W max and it seems not to be underrated. I have successfully melted 2 sockets at home by connecting portable Air Conditioner 1600W rated.
Hillhater wrote:Yes, beware.. its not just the breaker rating that needs attention, putting high amperage through domestic wiring and outlets for extended periods can result in overheated wiring, sockets contacts etc.. Take care !
Floont wrote:
I thought more about this and decided to go with the 1500W from: http://www.bmsbattery.com/alloy-shell/1 ... arger.html
Safety first. Never can tell if one day I'll plug it into the wrong circuit. My toaster draws 1500W, so I should be good.
parabellum wrote:...Never can tell if one day you just plug it in neighbors or friends or motels or gas station circuit.
o00scorpion00o wrote:I can pull 3KW from a wall socket easy here, my electric kettle is rated for 3KW!![]()
The shower circuit is rated for 30 amps @ 220 volts that's 6600 watts!
I think the main switch at the consumer unit is 63 amps, that's 13kw, that would be a very fast charger!![]()
The Nissan leaf pulls I believe, 3.5 kw. But afaik they are upgrading that to 6kw, can someone confirm that? I know they are supposed to be making the charger faster, though here on 220 volts that's easier?
back to the charger, how does one set these to output voltage while no battery is connected? I don't want a lipo explosion by turning the voltage too high!
Thanks
Mark
o00scorpion00o wrote:...The shower circuit is rated for 30 amps @ 220 volts that's 6600 watts!...
Floont wrote:o00scorpion00o wrote:...The shower circuit is rated for 30 amps @ 220 volts that's 6600 watts!...
What the heck is a shower circuit?
parabellum wrote:
I think that big chargers are a little different
Look here:
viewtopic.php?f=14&t=29096&p=419529&hilit=charger#p419529
o00scorpion00o wrote:parabellum wrote:
I'll never buy from EV assemble again, people should not trust them. After a few E-mails Michael stopped replying!
Mark
Mark
Another one bites the dust
Mark
Users browsing this forum: No registered users and 10 guests
