bmsbattery bms wiring question
Postby aaannndddyyy » Sat Aug 27, 2011 3:59 am
I have a bmsbattery bms its a little different from my signalab bms wiring which has a separate terminal C for the charger --wire
My question is which terminal dose the charger neg go on the bmsbattery bms to B- or P- ?
the only info I found is on there site http://www.bmsbattery.com/bmspcm/323-17 ... t-bms.html
aaannndddyyy
Re: bmsbattery bms wiring question
Postby krelle52 » Sun Aug 28, 2011 2:22 am
Hi
The charger shall be connected to P-. I have the same BMS as you :-)
/Krelle52
krelle52
10 µW
10 µW
Postby aaannndddyyy » Sun Aug 28, 2011 5:40 am
krelle52 wrote:Hi
/Krelle52
Thats Great Thanks. :)
aaannndddyyy
Postby jvr-ks » Mon May 21, 2012 10:55 am
Got the same BMS. There are 4 connection-points.
P- / P-
B- / B-
Am I right to connect:
left P- to charger -
left B- to battery -
right B- to controller
leave right P- open
Battery + to charger + and controller +
Thank you!
jvr-ks
Return to E-Bike Technical
Who is online
Users browsing this forum: phase_boy, sflorlando and 14 guests
