There is a myth floating around that says that the "Buck Converter" which is a PWM Controller does such a "magical" job in passing extra current to the low rpms that it can counter act the efficiency losses that low rpms always suffer...
xyster wrote:The fact that motors are less efficient at low rpms is independent of controller or no controller, hence any "controller myth" as it applies to motor inefficiency is a red herring anyway.
"Hey, reality is reality, I'm going to use a big battery and a big motor and not decieve myself into anything else. And my way works and it's more reliable anyway."
Leeps wrote:Just ask me about permanent magnet motor efficiency
Xyster seems to simply "agree" that while you can get a little bit "extra" torque because of the PWM effect it's not like you get it for "free". That "extra" torque "subtracts" from the efficiency at the same rate that it "adds" because you are INCREASING the current (through the effect) and therefore increasing the amount of energy DRAINED at the same time. (which counts as a negative)
Leeps wrote:...more current is available to the motor with less current being taken from the battery is it necessary for the motor to also consume this current, in your opinion?
Leeps wrote:In any case, you mention that the quantity of energy transmitted increases at a lower duty cycle. All I can say is justify it.
Leeps wrote:Suggesting that peak efficiency occurs at a point where power output drops off with increasing rpms, is also suggesting that peak efficiency is occuring around the power peak. Im sure this is not what you were trying to say.
Leeps wrote:If you had a battery that can supply for example 200 amps, is it necessary for the motor to consume said 200 amps. Now in the same breath the fact that there is a dc-dc conversion taking place, and thus more current is available to the motor with less current being taken from the battery is it necessary for the motor to also consume this current, in your opinion?
Can the toilet lid be lifted up or down?
Users browsing this forum: Dauntless, neithermovingnorstill and 8 guests
