2WD (Two-Wheel Drive) FAQ
cycleops612
Location: Sydney Australia, Me: 70kg/154lb. 350w, 22kg ex battery, 24 speed axial mid-drive Bofeili MTB.
Re: 2WD (Two-Wheel Drive) FAQ
Post by cycleops612 » Nov 23, 2017 6:33 am
PS.
My biggest fear w/ incurring the wrath of the local cops, is not having a plan B to make it kosher again once I have been warned once and noted. Simply removing/swapping the front wheel for road use I could live with.
To being precluded from the road seems a big/costly risk.
d8veh
Post by d8veh » Nov 23, 2017 7:36 am
You can use one throttle with more than one controller provided that you only use the 5v wire from one controller, i.e. don't parallel the 5v wires. If you're using more than one battery, you need to make sure that the grounds are linked to give one common ground. You don't need a buffer if you do it that way.
The problem that you need to avoid is that the 5v will not be the same on each controller, so you can get strange effects when you connect them, and the same thing if you don't have a common ground.
motomech
Post by motomech » Nov 23, 2017 8:08 am
cycleops612 wrote:
Nov 23, 2017 6:25 am
markz wrote:
Nov 22, 2017 9:23 pm
You are breaking the law, are you prepared for that?
I bet you'r fun at parties. :)
Just saying, my longyeah axial drive mid motor (24 powered gears) is only visible to the practiced eye (unlike the battery of course). I strongly suspect a second motor would pass notice.
What hasnt been mentioned afaik, is there are advantages to opting for powering each wheel optionally, vs sharing a controller, and it to some extent diminishes the need for full power to both from a single battery, tho I agree, more amps is better for when you do want both at full power(best avoided rangewise anyhoo). This is not the case when traction is the issue.
I also like regen on one (front ideally) but not both motors, due to the slight drag.
In theory, I think I would opt for a twist throttle, with an adjacent thumb throttle, and with practice, both controllable with one hand.
In theory????
On page 8 I show how I do it (w. pic.s) and explain that it works well.
Time for you to stop pretending you are charting unexplored territory and rather than rehashing our ideas, maybe you should build something and show us something new in your own build thread.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, 2.4 Holly Rollers run ghetto tubeless. 25 mph. Mean Well HLG-320H-48A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 12S LiPoly elifebike 9-FET 17A controller. 20 MPH.
https://endless-sphere.com/forums/viewt ... 8#p1237928
teklektik
1.21 GW
1.21 GW
Post by teklektik » Nov 23, 2017 9:51 am
In theory????
Seriously? You kept reading after 'shared controller'?
Alan B
Post by Alan B » Nov 23, 2017 9:57 am
just to be crystal clear, you cannot share BLDC controllers (unless the motors are locked together in the right phase relationship). BLDC's electronic commutation must respond independently to each motor's actual position.
You can share Brushed controllers (with brushed motors).
cycleops612
Post by cycleops612 » Nov 23, 2017 1:50 pm
motomech, more laboriously than "in theory", i meant i have not done it, but that seemed best from past reading & considering the matter for myself.
Its a v old thread and yes i saw your? late posts belatedly - it happens - boo hoo - why so upset?
it seemed relevant to the posters query & you confirm that - its simply a repeat.
Monkeypowah
10 µW
10 µW
Post by Monkeypowah » Nov 23, 2017 4:49 pm
Battery mount needed some alteration...drill, to let battery fit in frame, it was like 3mm from letting the lock hold it in place.
rear wheel mounted, test ride with everything taped on, nice acceleration, can't complain about this kit for the money, it slotted in perfectly, disc lined up spot on.
Left off everything like pedal assist, brake cutouts, it has a 3 led indicator on the twist grip which is suitable for warning aircraft at night, thats getting ditched.
Rassy
Post by Rassy » Nov 23, 2017 5:40 pm
Those 3 led indicators are set for a 36V sla battery so go super bright on 48 volts and don't give you any information except that the system is turned on. It's a good idea anyway to "cut" the wire that carries full voltage to the throttle which helps eliminate one potential source of a short. Of course I don't know which color that wire is. I think normally red, black, and blue/purple are the three wires needed for the throttle, but you would need to verify that.
-Rassy-
One Tadpole Trike equipped with a Bafang BBS02
https://endless-sphere.com/forums/viewt ... 28&t=69419
One Delta Trike equipped with a Bafang BBS02
https://endless-sphere.com/forums/viewt ... 0#p1291260
Monkeypowah
10 µW
10 µW
Post by Monkeypowah » Nov 24, 2017 12:23 pm
Thanks, probably going to put a thumb throttle on, I'll have to work out the wires by taking it apart just to be sure.
Ordered one of these to be built into a 24 inch rim, have to seriously widen the stays out to 175mm, but 80nm of torque should help a lot.
https://www.ebay.co.uk/itm/36-48V-500W- ... SwCU1Ytmyb
Monkeypowah
10 µW
10 µW
Post by Monkeypowah » Nov 26, 2017 7:27 am
I've instantly hit all the problems that the wise old owls on here warned me about, basically it works fine, I've got it just banging in the front hub, no problems, not enough torque to be an issue, things like the battery clanking away over rough ground are making the bike feeling like a tank.
Updates are, more securely, rubber mounted battery, 24 inch rims and a high torque fatbike hub in the rear, the battery is coping well.
Also bough a second hand downhill rear suspension frame, hopefully that will reduce the stress on the battery as well.
I'm not taking any pictures cos it looks like an electric scarecrow at the moment.
markz
Post by markz » Nov 27, 2017 8:21 pm
I was being facetious ( not meant to be taken seriously or literally: a facetious remark. 2. amusing; humorous. 3. lacking serious intent; concerned with something nonessential, amusing, or frivolous: )
in a sense because some people take the term 250W literally and go to extraordinary lengths to follow some bs law to the T.
I say since a 500W motors diameter is the same as a 3000W motors diameter (but much wider) no one will know nothing anyways. Im not scared of power legislated or otherwise 8)
tomjasz
1.21 GW
1.21 GW
2WD MAC
Post by tomjasz » Nov 29, 2017 1:13 am
Finally ordered the rear 10T MAC for my 2wd build. Anyone use MAC? I've a wiring scheme from teslanv. Any suggestions?
(228.14 KiB) Not downloaded yet
Two 12 FET IRFB4110 EM3ev Controller (Black Case). Not sure how clunky it'll look with two controllers and a bundle if wire to cover and hide away.
linear
Post by linear » Nov 29, 2017 3:17 pm
PS.
Yes, to incur the abuse of the LEO team, especially when they already have their focus on you is annoying to say the least. Most of my current project plans will no doubt cross the line in their minds.
Anyway, did order a pair of kits to experiment with 2WD, regen, and electric braking. Winter coming soon will really limit any use or testing.
Primary Battery: CR2032
csc
Post by csc » Dec 04, 2017 3:33 pm
I found a trick to push the slave speed limit in 2wd mode ! More details here : https://endless-sphere.com/forums/viewt ... 8#p1338398
