Kingfish wrote:The simplest solution is to craft a PCB with two CPUs with accompanying driver channels: We just have to agree on the features and set about making one. However I like Justin’s thought on using the CA to manage both throttles; it seems promising and I’ve yet to try that.![]()
BTW – I just want to say that 2WD and AWD systems are advanced topics for experienced users. I would strongly suggest noobs go build a single-wheel drive system first before venturing into this realm, because most of us here already know well the aspects of common components. In other words – if you’ve never built an ebike before, then this is the wrong thread to read and post your questions.
Thank you, KF
Thank you, KF
x1 = throttle_1 [0..1]
x2 = throttle_2 [0..1]
y1 = a1 * x1 + b1 * x1^2 + c1 * x1^3 (a1, b1 and c1 are in [-8 .. 8] range)
y2 = a2 * x2 + b2 * x2^2 + c2 * x2^3 (a2, b2 and c2 are in [-8 .. 8] range)
motor_phase_current = max_motor_phase_current * (y1 + y2)
Lebowski wrote:Are you guys familiar with my 30F controller ...
Lebowski wrote:
Are you guys familiar with my 30F controller build (http://www.endless-sphere.com/forums/vi ... 30&t=34231) ?
I'm building a full sinewave sensored/sensorless modified Field Oriented Control controller IC with everything configurable
to the user over RS232 (or USB with a USB<->RS232 cable)
The options I built in for throttle control are ideal for multi-motor setup..
Alan B wrote:Or get a Cromotor. Wait, this is a 2wd thread. Never mind.
Ian wrote:Alan B wrote:Or get a Cromotor. Wait, this is a 2wd thread. Never mind.
Hi Alan - read thru the cro thread and too big n'heavy for me I think- although I will keep an eye on people's experiences of it for lower speeds and modest power levels like mine.
Anyways apologies if my post was not totally on-thread but it is an attempt on my part to resolve the right design 2WD in my particular circumstances. Which I think is defintely worthy for 2WD. I am satisfied that using 1 battery of correct capacity, 2 identical controllers and 1 throttle is straightforwards and tried and tested. The evg frame fortunately is robust with strong front forks so again a good candidate. I need something similar in efficiency as my current 9c, at speeds 22mph and under. I get around 2 miles per ah in normal use, which is WOT on the hills, fairly easy cruising, then all the downhills.
At this time, I don't think there are even that many choices. 2 x 9C is to heavy. 2 x magicpie too heavy. 2 x smaller DD hubs might work but too much drag? Are there any mid-size DD hubs however, worth consideration for a 'middle of the road' 2wd setup?
So what I see as the only real choice is 2 of the 500w geared from cellman or 2 smaller geared hubs such as bafang. I don't know if a smaller geared hub even when doubled up will be strong enough or temp resistant over the long haul, so I would like to read anyones experience or crunch some numbers as it is definitely a stealthy look and good weight. 2 x cellmann 500w seems on paper to be the best choice. It means that weight remains about the same as my current 9C and also means I can configure my battery packs to go down to 40v and attain a capacity of 40ah, use a slow torque winding to get around a 22mph top speed, and tackle steep hills at a 'sweet spot' for each motor, around 12 to 14mph at say 800w draw on each for no longer than 1/2 to 3/4 of a mile at a time.
The benefits seem to be that I would gain greatly (in comparison with the 9c) from thermal efficiencies when going majorly uphill, freewheeling with pedal assist on the flat helps a bit more, and never overstressing the system at any point. Even at my highest theoretical draw of 20amp per motor, I am still only 1C on the battery pack, and when cruising on the flat from 18mph to 20mph, I would still expect to use only 350w combined or 175w on each hub - total 9amps on the battery or under 1/4c. Therefore, I should get a theoretical range of 70 -80 miles minimum on level road, is that correct?
Well I will keep learning and looking through all the posts and see what others have already experienced!
wojtek wrote:If i refer to auto industry, the whole point of AWD is when you lose traction in some wheels, the other will take over.
The only useful usage that would increase fun considerably would be to have AWG off road trike, used in extreme offroad conditions and on snow [putting aside the complexity of 3 WD]
I can't really see enough benefit of putting 2 motors on a standart bicycle. Put aside all the technical and mathematical calculations that some of geniuses has done here [full respect]
rojitor wrote:Ever since i turned my bike on a 2wd i noticed more stable rides, the weight at the front wheel makes a good balance, on top of that i can keep top speed climbing,sometimes i even pass gas motorcycles going uphill and i always know i can make it to home if i have a problem.Maybe with a cromotor or 54xx at the rear it is not so cool, time will tell.
Alan B wrote:The Cromotor is so wide there is little room for freewheel cogs and would not fit in most front forks. But 2 of them would be quite interesting.
Users browsing this forum: Chalo, Google [Bot], icecube57 and 9 guests
