Controller Power Board
Postby salty9 » Wed Nov 09, 2011 9:51 pm
A power dense controller might be possible by modifying the test strip made by LFP in http://endless-sphere.com/forums/viewtopic.php?f=14&t=15093&start=0. As I see it the drain of the high side FETS would be soldered to one copper buss and the source of the low side FETs soldered to the other. A phase terminal would be used at the FET junction. Caps recommended by Bigmoose would bridge the busses. Gate drivers and resistors would need to be integrated. Multiple FETs per phase could be made by sandwiching the buss between the FETs.
salty9
Re: Controller Power Board
Postby salty9 » Sun Nov 27, 2011 9:42 am
This is a very rough sketch of the design I was trying to describe in the OP. The drain bus, source bus and the junctions would be copper. This is not intended to be a controller design but only a suggestion.
salty9
Return to E-Bike Technical
Who is online
Users browsing this forum: agniusm, dnmun, pchen92, The Stig and 15 guests
