ebikes-sf
I was curious and compared latest V2T (with V4 clutch and doubled phase wires) and V4T side by side, ran only a few tests, wouldn't say my testing was thorough, because not all planned tests were completed (different amps, load, rpm, etc...), but according to the data I was able to collect, there doesn't seem to be any difference. Seems V2T and V4T is the same motor only V4T is more expensive. But if higher top speed motor is desired, there is no other choice than V4C or S because V2S (similar to V4C) and V3 (similar to V4S) have been discontinued.
Tests were conducted up a quarter mile hill with varying grade, used Lyen Mark2 controller limited to 30A, 16S LiFePO4, 26" wheel, big dummy frame, CA with datalogger. Here is the data from CA datalogger:
http://www.ebikessf.com/sites/default/files/images/endless-sphere/V2t-vs-V4T-hill-30A.xls
I will run more tests with torque, cruiser and speed motors, but suspect claims of up to 10% increase in efficiency are false.
