The Unofficial 'CroMotor' Owners Tech-Tips Thread
Re: The Unofficial 'CroMotor' Owners Tech-Tips Thread
Postby gensem » Tue Jan 31, 2012 12:50 pm
As promissed..
Wheel is dirt because it was parked for some time.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby Alan B » Tue Jan 31, 2012 1:05 pm
Wonder if JRH would be interested in getting a boxfull of them...
The 2.5's are the size I'm planning to use. Those tires look good!
Alan B
1.21 GW
1.21 GW
Postby dangerzone » Tue Jan 31, 2012 2:37 pm
gensem wrote:
Yes, they are 9g... and they are motorcycle spokes (UCP, not stainless steel), as far as I can tell regular bicycles use 15g-13g spokes. JRH has 12g spoke but I think you would need a washer in the cromotor flange.
8 G / 4mm
9 G / 3.5mm
10 G / 3.2mm
11 G / 2.9mm
12 G / 2.6mm
13 G / 2.3mm
14 G / 2.0mm
15 G /1.8mm
Yeah, that will be good, I think it might even withhold some slight off road fun trails or riding up/down stairs... Yet your bike would need some really good rear suspension for such rougher fun. :)
dangerzone
Postby dangerzone » Tue Jan 31, 2012 2:55 pm
Andje wrote:Hah! I have relied on them at 100km/h commuting for about 8000km and they have been fine; 18$ Tioga 1.95's with about 90$ worth of tube kevlar tape and rim tape inside it. I would expect them to burn on the race track with tight turns as you say.
What I meant was that there has been a trend just recently of using these moped rims and mbike tires; they look totally badass and I'm having trouble enjoying the look of kenda flames or holle rollers the same way. There is no doubt these are safer, maybe cheaper, but heavier and won't fit every frame; bike tires have been getting a bad rap as we push these things faster, but what Luke does with his 3-400 pound "bike"+rider weight on the track is not comparable to many other peoples situation. If you are running a hub motor on the street as a commuter I would be upgrading to get the stronger rim, not the stronger rubber, but that's just me; I have found the rim to be the week point in my hard tail builds, with a DS bike I wouldn't even be worried. Is there ANYONE besides Luke that can really say they raced their ebike to the point that the side walls of their tires failed? I will take my hat off to them as well, for I am in awe.
Well, I have been riding bikes for some time and motorbikes are something completely different than bicycles when it comes to handling. Even after a few weeks of riding motorbikes when you sit on a bicycle everything feels weird, too light, to clumsy in a way... I did try to lean with a bicycle quite a few times only to find that the rubber of the tires is the weakest link, it does not hold as good as the rubber of a motorbike tire in tight turns. Then there's the problem of bicycle tire sides which are not made of softer material as motorbike tires are. I'm just saying that I would always feels safer with a good (soft) motorcycle tire on my wheel than a bicycle one with the Cromotor in the rear hub. If some cyclists have different experiences I would surely like to know their technique or some tips&tricks... ;)
dangerzone
Postby johnrobholmes » Tue Jan 31, 2012 2:56 pm
I would be interested in a box of them, but if I'm gonna get a box I want a deal :lol:
Here is a wheelset that is shipping out today to Canada. On the cromotor I used 108mm 12ga spokes with brass washers under the heads, 17" rim with erd of 420mm, and Gazelle 2.5" moped tires.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby dangerzone » Sat Feb 04, 2012 4:10 am
johnrobholmes wrote:Order placed for the 11/12 butted spokes in straight pull and 90 degree heads, it will be about 6 weeks now. We also have larger 6mm body nipples coming for 12ga and 13ga spokes to adapt to anything we need.
Here is a little wheelset that we put together for a fella in Canada. Thanks for the build, it is a nice wheelset you have coming!
17" moped rims and Gazelle tires. Should be a blast!
Hey John Rob Holmes, this wheelset looks really tidy and neat.
Yet I do have a question about the lacing on the rear wheel. You laced the front wheel as it usually is laced, every second spoke is laced from the inside to the outside of the hub. But on the rear hub all of the spokes are laced from the outside to the inside, you can see all the spoke head butts are facing towards us. Now, most of the bikes have it one-in-then-the-other-out system to avoid spokes grinding onto each other, like on the front wheel. IS there a particular reason why you laced the rear wheel that way or was it a question of design..? It sure looks extraordinary. ;)
Gensem, I do have a question about the longer spokes that you used for the first setup, which ones are those, looks something like 150mm and 3mm..?
I think that there might be some old Jawa spokes that could be angled to fit without bends. I just haven't got the motor with me to try to put it in a 17' wheel rim, but will try some more options once I get it. I was just wondering how long and thin are those spokes on this picture..? ;)
dangerzone
Postby johnrobholmes » Sat Feb 04, 2012 8:38 am
The rim I used is fairly narrow (for 2.25 through 3" tires). If the hub was shorter or the rim had wider hole spacing I would use regular alternating patterns more readily, and I actually did this on one of the cromotors. It was a bear getting the spokes seated and set, so I opted for all heads out (inbound spokes) on this build to keep from fighting the outer spokes so much. Another issue with lacing alternating is the inbound and outbound spoke lengths are not the same. It is possible to build either way, and either way will build a suitably strong wheel.
I would recommend an extra 2mm length on the heads in (outbound) spokes if you choose to alternate the pattern in a 17" rim.
Volt up, gear down!
johnrobholmes
Postby gensem » Sat Feb 04, 2012 12:28 pm
I dont remember the length because it was an off the shelf spoke, but it should be something 140-150mm space and it was 3mm.
Btw that wheel no longer has a 2.15 rim and 2.75 tire. I has now a 1.4 rim and 2.5 tire.
gensem
Postby gensem » Sat Feb 04, 2012 2:05 pm
2.75 tire vs 2.50 tire laced to cromotor.
gensem
Postby neptronix » Sat Feb 04, 2012 2:43 pm
gensem wrote:2.75 tire vs 2.50 tire laced to cromotor.
Thanks for the size comparison. I think the 2.5" is definitely enough for most standard bike frames.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby gensem » Sat Feb 04, 2012 2:46 pm
Neptronix, using the same 17 1.40 rim the 2.75 wouldnt fit in most regular bikes. But I wont deny it looks alot better with 2.75, looks really pushy.
My caliper is telling me that the 2.50 tires has 2.6inch diameter and the 2.75 tire has 2.90inch diameter.
gensem
Postby GCinDC » Sat Feb 04, 2012 8:45 pm
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby gensem » Sat Feb 04, 2012 10:36 pm
Thats a really long drop out, I would dare to say too long, for the stuff i saw in your videos... but that was a reminder to be carefull with my catapult.
gensem
Postby zombiess » Sun Feb 05, 2012 5:18 am
gensem wrote:Thats a really long drop out, I would dare to say too long, for the stuff i saw in your videos... but that was a reminder to be carefull with my catapult.
Just wait to you see what I have my friend fabricating for my exhibition of acceleration bike.
This is what I have now
Rides nice, corners great and that swing arm is extended 8 inches. Problem is I can barely run any phase amps into the motor at 125V because it doesn't matter how far I lean over the handle bars, it will loop me off on a hard launch. New version is most likely going to be 16" or 20" longer with a different shock mount so I can use a longer shock with a stiffer spring I already own vs this very nice 140mm Cane Creek Cloud 9 air shock so I can go hunting just about anything from a dead stop to about 50 mph :) Should be scary fun.
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Postby fractal » Sun Feb 05, 2012 8:22 am
GCinDC wrote:
nice!!!!! can you provide any details???
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby GCinDC » Sun Feb 05, 2012 8:35 am
dbaker is the man for details.
all i can say after testing it is: :twisted: :twisted: :twisted:
and his old 24s pack was sagging hard.
GCinDC
1 GW
1 GW
Postby patrickza » Sat Feb 11, 2012 11:09 am
How have you guys managed to mount your disc breaks? With my bb7's and 203mm rotor there just isn't any clearance for the inside of the caliper...
The way I see it I have two options. Either use a spacer, or try to find a 10inch rotor. I like option number 2 more, anyone know where I can buy a 10inch rotor?
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Postby Alan B » Sat Feb 11, 2012 11:12 am
The local hardware store has 10" rotors. They have a little extra material you need to remove. Check in the table saw aisle. :)
Alan B
1.21 GW
1.21 GW
Postby hillzofvalp » Sun Feb 12, 2012 10:08 pm
I'm thinking about water jetting my own disc if I run into this issue. will any faced 1/8" stainless do the trick with enough support?
hillzofvalp
Postby zombiess » Sun Feb 12, 2012 11:04 pm
My 203mm rear fit fine with my Hayes Trail but it's really close. All my stuff is done custom, probably not as much issue on a normal bike. Avid Juicy calipers are much smaller.
GreyborgUSA Dealer
zombiess
Postby Lavolta » Tue Feb 14, 2012 3:58 am
Here is CroMotor number 9 laced into an excell 19" rim.
I was planing to only use a 180mm rear disc with Hope 6Ti caliper but it is too wide.
(92.38 KiB) Downloaded 7 times
Cheers
Bruce
Lavolta
10 µW
10 µW
Postby andreym » Thu Feb 16, 2012 1:59 pm
If you have only 135mm of dropouts and still want to fit some torque arms inside, you can use the following disk rotor adapter mod:
-remove original adapter,
-get avid g2c2 203mm rotor
-get magura gustav M rear brake for enough clearance
-dremel a bit of avid rotor to make it fit and screw it up INSTEAD of original adapter
here is your additional ~5mm clearance for torque arms with CroMotor and 135mm of dropouts!
and some pics:
Avanti D8 CroMo frame, CroMotor :) + MAX-E controller. 18s10p zippy compact in Pelican 1300 case. 1.8kwhrs total usable capacity.
fast 1.2kw charger old GT iDrive e-bike
andreym
Postby MadRhino » Thu Feb 16, 2012 6:24 pm
Lavolta wrote:Here is CroMotor number 9 laced into an excell 19" rim.
Cheers
Bruce
Nice wheel, have you measured its weight, complete as shown?
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby gensem » Thu Feb 16, 2012 7:34 pm
he is using thin spokes... so I would guess around 14-15kg
gensem
Postby MadRhino » Thu Feb 16, 2012 7:48 pm
gensem wrote:he is using thin spokes... so I would guess around 14-15kg
He's using heavy rim and tire, I would guess more than that.
Work in progress:
Trek Session 10
Fatboy
MadRhino
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: Bing [Bot], wojtek and 14 guests
