xyster
After connecting in series new subpacks last month using crimped quick connects and a quick connect adapter, I noticed my batteries' apparent voltage sag more than doubled -- from 4 volts to 10 volts at 35 amps. Suspicious, I just replaced the quick connects
and adapter
with a good 'ol screw-on wire nut.
Voltage sag at 35 amps is now 6 volts instead of 10! Wow, that's almost like getting a whole extra 4 volt lithium subpack for free!
I've still got other quick connects and crimped wire butts (sounds like me after a long ride )
I'd like to replace, but they're stuck inside very tightly packed battery boxes. There isn't room for wire nuts, powerpoles, or bolted ring terminals, and I don't want to solder those wires together.
Any other ideas?
Any similar experiences out there?
and adapter
Any other ideas?
