Long Term testing of an ATS Speed Drive
Re: Considering a Schlumpf High Speed Drive
Postby markobetti » Thu Apr 12, 2012 12:22 pm
Alan B wrote:ATS makes a licensed version of the Schlumpf. Accountant sells them.
Exactly
markobetti
Postby gensem » Thu Apr 12, 2012 12:26 pm
Where can I find chain ring and cranks?
ATS itself does no reply to emails.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby Quajochem » Thu Apr 12, 2012 12:30 pm
I had the same problem, but you can PM Dimitri (forum member Accountant). Because he bought 50 drives, and still has some left I just ordered one from him with cranks :)
The chain ring is standard, you can order that anywhere..
Quajochem
Postby MattyCiii » Thu Apr 12, 2012 12:37 pm
Yes the chainrings are 130mm BCD
EDIT: WRONG! They're 110mm BCD. Keep reading this thread...
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby gensem » Thu Apr 12, 2012 12:39 pm
Quajochem wrote:I had the same problem, but you can PM Dimitri (forum member Accountant). Because he bought 50 drives, and still has some left I just ordered one from him with cranks :)
Hes is name is Vladimir!! I already got two ats drives from greyb.org, but now I need the crank arms and rings.
gensem
Postby gensem » Thu Apr 12, 2012 12:41 pm
MattyCiii wrote:Yes the chainrings are 130mm BCD
ATS says the chainring is 110mm, have you got a 130mm installed in yours?
http://ats-speeddrive.com/tpl/all_sd_item.html
gensem
Postby Quajochem » Thu Apr 12, 2012 12:47 pm
Sorry I thought you ment the ring with the teeth on it, or chainwheel, you are talking about the protection ring?
My order hasn't actually arrived yet, I think I ordered no protection ring or chainring at all, because I am planning to use it with a standard chaincase wich I will modify..
The number of teeth will be 38 or 40, I don't know how much that is in diameter.
Quajochem
Postby Quajochem » Thu Apr 12, 2012 1:00 pm
But the chainring and chainguard are both standard 5 hole bolt on items, so there's no need to order them from ATS
Quajochem
Postby melodious » Thu Apr 12, 2012 1:04 pm
This may be of interest for a chainguard. I saw it at my local bike store on folding bikes (Dahon). Its a plastic coil conduit with a split in the middle. Looks cool in person.
http://www.chainrunner.de/index_en.html
Went and surfed around for it and it may lack any real durability factor. Who knows. But it definitely adheres to the "simple looks" of this thread.
melodious
Postby gensem » Thu Apr 12, 2012 1:08 pm
Quajochem wrote:But the chainring and chainguard are both standard 5 hole items, so there's no need to order them from ATS
Regular chainring has BCD 104mm and regular crank arms do not fit too.
So... where to get the cranks and the chain ring?
gensem
Postby Quajochem » Thu Apr 12, 2012 1:16 pm
Vladimir (Accountant) told me this about the chainring:
"Ebay is your friend. Look for 5 holes standard chainring.
Any bicycle shop have this in many collors and variations."
And you can contact him and ask him about the crank arms wich I ordered withthe drive, he has 172,5 mm crank arms, maybe you're lucky and he will sell them seperately from the drive, because those cranks are definately not standard no..
Quajochem
Postby Quajochem » Thu Apr 12, 2012 1:29 pm
melodious wrote:This may be of interest for a chainguard. I saw it at my local bike store on folding bikes (Dahon). Its a plastic coil conduit with a split in the middle. Looks cool in person.
Yeah that's really cool looking!
but:
+ looks
- water, salt water > rust = maintenance
Looks possibly even cooler than this chainglider:
http://www.bikeradar.com/gear/category/ ... ider-33772
+ It rests on top of your chain rather than attaching to your frame, so also no additional mounting
fixtures needed.
- Sand can make it noisy and wear out fast
New model :!:
http://www.hebie.de/Chainglider-open-35 ... .html?&L=1
Still recommendable for all of you rear hubmotor enhousiasts! The chain will stay clean and lubricated longer :)
Quajochem
Postby MattyCiii » Thu Apr 12, 2012 2:53 pm
EDIT: I was wrong, they're 110mm. I hope I did not steer anyone wrong. I guess I can use the wrong-sized chainring I have on order from Amazon as a wall clock face... :oops:
MattyCiii
Postby Alan B » Thu Apr 12, 2012 7:36 pm
I purchased a chainring from ebay and it fits. I'll have to check the size. Here is the info on the one I bought. SRAM 36T, 110mm BCD.
I've been told the crank arms are also a standard item but I don't know which "standard" they are. Mine are from Accountant. Seems like I put a photo of them in this thread earlier... No, it doesn't seem to be in this thread. Probably in my Greyborg thread.
Alan B
1.21 GW
1.21 GW
Postby Quajochem » Fri Apr 13, 2012 3:29 am
I have a Nuvinci rear hub, and I am also worried about the chainline, if it isn't straight enough I'll need some spacers!
From the ATS website http://www.ats-speeddrive.com/tpl/all_sd_tc.html :
"Chainline
Distance between centerline of frame and midth of chain: 41.7 ~ 51.7mm. The chain line of speed-drive can adjust by spacers. Any chainline in between 41.7~51.7mm. We can offer the right spacers to fit your bike."
Compatibility
Generally, you can combine any bicycle gearing system with speed-drive.
For heavy use such as for Long Johns, rikschas, tandems, please use hubs, which are designed for tandems. These are 3- and 5-speed - SRAM - hubs. With 7-speed-hubs from SRAM, Shimano hubs and all types of chain derailleur systems no problems have been reported in the past couple of years, when thousands of speed-drive - systems have been combined with many different gearing systems.
You can combine speed-drive with the Rohloff 14-speed hub.
All speed-drive - systems may be combined with coaster brakes.
Nothing is said about a Nuvinci hub... fingers crossed
Quajochem
Postby Accountant » Fri Apr 13, 2012 4:01 am
Hello everyone,
This is what I can offer :
ATS speed drive 1:1,6 ratio. It is not a cheap chinese copy. It is manufactured in Taiwan under original licence :
Now it comes with original cranckarms,black, 172,5 mm long, which I bought in Switzerland directly from Shclumpf :
If you are realy rich, buy original product. It is Swiss quality and it will last at least 200 years, like Swiss watches.
I think that it is beautifull, but also it is pure overkill at the same time...
Speed drive is more than good enought for the job, and will also last about up to your lifetime.
Chainrings can easily be obtained from ebay or local bicycle shops. They should come with 5 holes 110 BCD standards
Accountant
Postby Quajochem » Fri Apr 13, 2012 4:53 am
gensem wrote:Where can I find chain ring and cranks?
Those crank arms also look very standard to me! Correct me if im wrong, but the only thing that isn't standard is the bracket itself, those shift buttons are part of it..
Quajochem
Postby Accountant » Fri Apr 13, 2012 7:01 am
WRONG.
I was looking for apropriate crankarms for a few months.
Did not found them, and at the end bought from Schlumpf directly.
Very hard too find crancks that will work well with shifting buttons.
Accountant
Postby MattyCiii » Fri Apr 13, 2012 7:23 am
Quajochem wrote:I have a Nuvinci rear hub, and I am also worried about the chainline, if it isn't straight enough I'll need some spacers!
My setups are the same... I'm retrofitting one bike that already has a NuVinci with an ATS drive, and building a second bike up from the frame to use both the ATS and NuVinci. I have 2mm and 4mm spacers on the way just to give me options. I'll post pix when I get the parts in.
MattyCiii
Postby Quajochem » Fri Apr 13, 2012 8:16 am
Accountant wrote:Those crank arms also look very standard to me!
WRONG.
What exactly is different then? Is it the size of the square hole?
Quajochem
Postby kfong » Fri Apr 13, 2012 8:21 am
Accountant, how much plus shipping to Mi. 48310 USA?
kfong
Postby Quajochem » Fri Apr 13, 2012 8:29 am
great!
Quajochem
Postby Accountant » Fri Apr 13, 2012 10:01 am
What exactly is different then? Is it the size of the square hole?[/quote]
Depth is different, and cranckarms are thinner than usual.
Prety tricky.
Accountant
Postby MattyCiii » Sun Apr 15, 2012 11:58 am
OK, awhile back in this thread I promised I'd post some pics of the ATS drive installation. Well here goes.
I rented the tool set from ebikessf.com. They have an excellent installation video that was my guide. Renting the tool set was about $50 all told (that's rental plus shipping to me/back to ebikessf). Refund of $350 deposit was prompt. Very happy with how this is going so far...
Renting the tool set was very worthwhile, as I bought 3 ATS drives to install on 3 bikes. So, my cost per for installation is about $18.
Here are the pictures.
The most important part of the tool set: The chamfer tool is centered in the picture.
Here's bike #1, my spare bike. It's a 2007 Dahon Jetstream with NuVinci N360 rear hub. A great, versatile commuter bike. The ATS SpeedDrive will give me more gear range without the hassle of putting front chainrings on a folding bike. Here's the BB shell prior to chamfering.
A crank puller and bottom bracket removal tool are a must.
Another view
Here's me, using the chamfer tool the hard way (there are two springs, use them as shown in the video or get ready to spin that nut on the right a whole lot more than you need to)
A bike stand would have been nice, keep my back from aching, but it's easy enough to chamfer the BB with the bike upside down on its bars
Side 1: 45 degree chamfer, smooth and easy:
Side 2: Just as easy, but starting to get the hang of it so I didn't need to take the tool off & inspect quite as often
The "nut" you use on the left crank size has the mating 45 degree chamfer and can be used on both sides to gage depth
Once I got everything chamfered, I tried to mount the drive tightened to specification. But, the nut bottomed on its threads before I could apply torque. I had to order thicker spacers (they come in 0mm (pictured, I think), 0.5mm, 2mm, 4mm and 6mm). The spacers help with my problem (BB too narrow) and probably chain alignment too - which is why I ordered some 2mm and 4mm spacers.
Here's the spacer cone the drive arrived with.
My rental of the tool set from ebikessf was for one week. Though I was done with the chamfer tool (on all three bikes), I still needed the rest of the tools - especially the "box spanner" for tightening the bottom bracket nut - once the new cone spacers arrive. I suppose I could have called/asked to stretch my rental a day or two if I thought the larger cone spacers would arrive imminently, but I was not comfortable with the shipping timeline on the spacers.
So, I bought my own box spanner from Utah Trikes. I bought some of my cone spacers from them, and the shipping was something like $9 flat rate, so why not? If I need to remove/service the Speed Drive, having my own spanner can come in handy. If I thought a bit longer about the purchase I would have had them throw in this kit, but since I missed the window on fixed price shipping I'll just improvise with tools I have on hand.
I'm still waiting on my spacers - once they arrive I'll show the rest of the installation.
MattyCiii
Postby Quajochem » Sun Apr 15, 2012 5:24 pm
Pff, looks complicated, spacers, more special tools... :?
Hope the chainline will be right first time...
But let's watch the video first :P
Quajochem
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: dnmun, MattyCiii, motomech, scphantm, wesnewell and 12 guests
